Floody 18650 powered head lamp!
Afroderp
North Carolina!
tl;dr - I am a network engineer and work up high on lifts in darker areas. I KNOW it is overkill, but I would like a headlamp that has flood for areas I'm in, but also is capable of outputting some lumens (The HC60 comes to mind). The flood is for my everyday use, and the lumens would be just to mess around with. I already carry an 18650 powered light with me, hence the power source choice. I know I already carry a light, but due to carrying a ton of tools with me, my hands are full and I need a dedicated headlamp. The headlamp should also be pretty durable, as it's going to get roughed up a bit.
I'd like to keep the budget around $50-60 or so if possible.
Thanks in advance!
==================Flashlight Recommendation Checklist================
____This will be mail-order or Online (location doesn't matter).
2) Budget:
____Up to $60
3) Format:
____I want a self-contained headlamp.
4) Size:
____I don't know/I don't care.
5) Emitter/Light source:
____LED (known for efficiency, longevity, and compactness)
6) Manufacturer:
____I want to buy a light from a large/traditional manufacturer that is ready to go out of the box.
____I intend to use Rechargeable cells based on less common formats (18500 or 18650 Li-Ion, RCR123, et-al).
____I want to navigate a dark room or read a map (1-10 lumens).
____I want an indoor "blackout" light (15-50 lumens)
____I want to confidently walk around an unlit/unpaved rural area (60-150 lumens).
____I want to illuminate my entire backyard or a campsite (150-300 lumens).
____I want to illuminate an entire field, the neighbor's front yard several houses down, impress my friends and neighbors, etc. (300-700 lumens).
____I want search and rescue type illumination (800+ lumens).
____SPECIAL NOTE: Burst/Turbo mode Category - There are several lights that will run at a super bright maximum for a very limited period (usually 5-10 minutes) and then will "step-down" to a lower level for thermal control. Check here if this is acceptable.
____Wide Flood: I want a defined flood area for semi-close tasks like after-dark campsite tasks or working on a car.
____Narrow Flood: I want a sharply defined flood area that will project some distance for tasks like trail walking.
____Less than 1 yard/meter (reading, other close work)
____Less than 5 yards/meters (looking for something inside a dark shed/garage/basement)
____5-20 yards/meters (check out a noise in the backyard)
____30-60 minutes (I have plenty of batteries just ready to be changed)
____90-120 minutes (Runtime is moderately important, but still not critical)
____3 hours + (I critically need this light to run on max for extended periods in between battery changes/charges).
____Critical (Police, Fire, Search & Rescue, Caving, Survival).
____Any size switch will do.
____I don't care.
____I want multiple light levels. (Some lights have 5-16 light levels.)
14)Material/Finish/Coating
____I don't care.
15) Water resistance
____IPX4 (Splash resistant)
16) Storage conditions
____In luggage or on my head. Mostly controlled.
Str8stroke
On The Black Pearl
I would look at the Fenix HL55 or Nitecore HC50 I like that these have the 2 band headband. I find 18650 lights are heavy and a single band seems to slip or you have to set it so tight you will have a mark on your forehead for days. lol If you shop, you should find these for around $60 in a few spots.
kalel332
I would stay away nitecore, their customer service is terrible, I say this from experience. I own the Armytek Wizard and its pretty good. It has great moonlight modes {yes more than one moon light mode} and on turbo it goes up to 1300 lumens or so. I use it for cave exploring a couple of day ago and it was great.
eraursls1984
Tallahassee, FL.
I think the Zebralight H600Fw (flood with some throw) or the H602w (all flood) would fit the bill. They are one sale for $69 since the newer versions are out.
MX421
Texas
Zebralight H602w (all flood). They are one sale for $69 since the newer versions are out.
+1 I love mine so much i bought a spare. The older H602(w) isn't much dimmer than the newer H603(w) and as pointed out, the H602 is on sale. Have fun!
