Manker E14 II 2200 Lumens 18650/18350/CR123 Copper Head EDC Power house flashlight is
Manker
Manker E14 II 2200 Lumens 18650/18350/CR123 Copper Head EDC Power house flashlight is releasing
Specification:
Emitter: Cree XPG3 LED or Nichia 219C LED
Maximum 2200 lumens output
Maximum beam intensity: 6000cd
Maximum beam distance: 155meters
Waterproof standard: IPX-8, 2M
Impact resistance: 2meters
Working voltage: 2.7 - 4.2v
Driver: Most efficiency constant current circuit
Material: Aircraft-grade aluminum body
Surface treatment: Premium type III hard-anodized anti-abrasive finish
Lens: Toughened ultra-clear glass lens with anti-reflective coating
Dimensions: 78mm length x 27mm head diameter
Weight: 94gram (without battery)
Accessories: O-ring *1,Extension tube *1,Lanyard *1, Holster *1, pocket clicp *1, USB charging cable *1, high drain 2600mAh 18650 battery *1
Brightness Levels & runtime:
Moonlight 0.1-5lm >240hrs,
Low 22lm 38hrs
Medium 140lm 10hrs
High 850lm 3.5hrs
Turbo 2200 - 850lm 40s -1hrs (Max 2200lm output, after 40s stepdown to 850lm)
Strobe 2200lm
More details please visit:
http://www.mankerlight.com/manker-e...argeable-flashlight-high-drain-18650-battery/
markr6
:twothumbs Yet another light I need to buy. I'm assuming the 219C is 4000k like on the older E14?
