SUNWAYMAN C12CC-A Button Dual-Lights Mini Flashlight
sunwayman
SUNWAYMAN C12CC- 820 Lumens Dual-light EDC Flashlight
41c7419bd41381c8b1fb2920fa2300a3
d26187dd440fe815262b812336672cea
7f83f6badb0c90ba7abb9dac521a4ec7
6f74ab7da124290d9b8ad9e5c5936661
f24b57276e2f5693f97beb7e2f390b45
5d72212dcb51164c2313fbab346d66aa
cb43b715f1c1d6da678a8b7a4bd099a2
088f101b89e91a20063917bc8a4740a4
53eea4ce52aa7ceca5eb4478cfe35a05
7d1c44cb974d8209833353b5f74586ea
8288a874dad7d135ecbcf6294cd16118
c354b4f13881efe77b9e7444e400a9dd
Features
● Main Light Cree XM-L2 U2 LED, Side Light Cree XP-G2 R5 LED,with a lifetime of up to 50,000 hours
● Output mode:Main White Light-Turbo ( automatically lower to High after 3 mins continuous use) /High / Mid / Low / Strobe / SOS
● The tail is designed for charging, it will power off when it is loosened
● Stainless steel crenelated bezel at the tail
● Constant current circuit, constant output
● Effective range of 210 meters
● Uses one single CR123Aor 16340 lithium battery
● Working voltage: 2.9~8.4V
● High quality metal smooth reflector for main light maintains great throw distance and spread with an ideal beam pattern; Side light uses optical lens providing soft light
● Dimensions: 84mm (length) x 28mm (head diameter) x 24mm (tail diameter)
● Weight: 45.8g ( battery excluded )
● Tail-stand capable, can be used as a candle
● Aerospace-grade aluminum alloy, Stainless Steel retaining ring on the top
● Military Specification Type III- hard anodized body
● Waterproof, in accordance with IPX-8 standard
● Ultra-clear tempered glass lens resists scratches and impacts
● Accessories: Clip, Lanyard, O-rings
