Flashlight Suggestion for Soldier
Nephron44
Hey everyone!
My buddy is being deployed soon, and I want to put together some kit for him as a gift. In the kit, I want to put in a nice personal light.
Details about his assignment:
Location: depends on the political situation in a few months
Job: Medical, mostly on base, with some spec ops (can't go into much more detail than that)
Already issued lights: Surefire weapon lights (not sure of model) for both rifle and pistol, Surefire 6px Tactical
I'm looking to get him something small, durable, dependable, and easy to use/hold with gloves on. I'm thinking one cell cr123 or AA since he already had a two cell 6px. I want something that's super portable and pocketable for use on base, but also capable for use "in action" in a pinch if he had to bug out quick.
Any thoughts?
Thanks!
Edit for questions:
No preference
2) Budget: An easy question, but you may change your mind after answering the rest! :)
Up to 250 USD
3) Format:
Hand held flashlight
4) Size
Small, pocketable, but easy to use with gloves on
5) Emitter/Light source:
LED
6) Manufacturer:
I want to buy a light from a large/traditional manufacturer that is ready to go out of the box.
Single cell disposable cr123 or AA
8) How much genuine out the front (OTF) light do you want/need?
High mode enough to navigate/clear a building, low mode enough to navigate a dark room to safely get to the bathroom without waking bunk mates
Good mixture of both
Other side of a large room
1-2 hours on high
Critical (Police, Fire, Search & Rescue, Caving, Survival).
Tail cap, large enough to use with gloves
At least 2 modes (high and low). I'm ok if there is also strobe, but it isn't necessary.
14)Material/Finish/Coating
Metal, black
15) Water resistance
Realistically waterproof (rain, drop in puddles)
16) Storage conditions
Pocket
Pocket clip, easy to find/obtain replacement parts
archimedes
CONUS, top left
This thread will be moved soon to the " Recommend... " subforum, but please take a look at the pinned sticky (questionnaire) there.
Your request is rather vague on specifics, so you will get better advice, if you "copy-paste" that post with your (his) needs and wants with regard to this torch.
Cheers !
As a starting point, you may also want to look at HDS, and see what you like (or don't) since many here may suggest that particular choice :)
Nephron44
Cheers !
Thanks! I'll heed your advice and edit my post.
Nephron44
Cheers !
Updated! Thanks!
Str8stroke
On The Black Pearl
HDS Rotary Black Bezel RAISED BUTTON would be a great suggestion. Easy to use with gloves too. Tons of lighting options. I would probably do a holster? Not sure if they have room on their waist for that. IF they are are against a holster, then a clickie with Raised button would work well if they must have a pocket clip. I would take it a step further and get them a Custom with High CRI version. That way they have a variety of lighting options.
Other ideas:
Elzetta Alpha with flood lens & High Low tailcap
Surefire Aviator New single cell version
Nitecore SRT3 (budget offering)
Modernflame
Dirty Dirty South
Other ideas:
'Nuff said.
aginthelaw
NJ, USA
Since the hds was already mentioned, I would also recommend the zebralight h32 or h302 headlamp
TMedina
A couple of thoughts:
1. stick with a single CR123. He's already going to have those cells coming out of his ears with the rest of his kit.
2. Surefire is running a sale on their flashlights through this weekend. I'd go with either the Aviator with a non-white secondary; amber or blue, given his role. Or the EB1 Maxvision backup.
Tell your buddy to keep his head down.
