Trit
- Joined
- Jul 31, 2016
- Messages
- 9
Howdy Team!
Firstly, thanks to everyone who recommended me the Eagletac D25C clicky as an EDC - it's been fantastic and better than anything I would have found on my own. I've come to ask for some further advice regarding a light for animal tracking.
Whilst there are several flashlights out there which have dual white and red LED modes, the red always seem to play second fiddle to the primary white mode. I'm after something similar to the HDS rotary with red LED option, but without spending HDS money. This may not be possible, but thought I would ask! Variable output - ideally with rotary function would be ideal, but the necessary feature is Ann output of around 200-300 lumens (with ability to go lower), combination of flood and distance of possible.
Thanks in advance for your help!
T
=====Flashlight Recommendation Checklist====
I now live in New Zealand, doc online may Ben the easiest option here.
2) Budget: An easy question, but you may change your mind after answering the rest!
Up to $100
3) Format:
I want a flashlight (hand held/self contained
4) Size:
____SMALL - Every day carry (4-7 inches).
5) Emitter/Light source:
____LED (known for efficiency, longevity, and compactness)
6) Manufacturer:
____I want to buy a light from a large/traditional manufacturer that is ready to go out of the box.
____I would like a light from a specialty manufacturer (Possibly limited run/Custom).
rechargeable but I don't mind which
____I don't care
200-300 lumens
____SPECIAL NOTE: Burst/Turbo mode Category - There are several lights that will run at a super bright maximum for a very limited period (usually 5-10 minutes) and then will "step-down" to a lower level for thermal control. Check here if this is acceptable.
I don't need a burst mode
____Narrow Flood: I want a sharply defined flood area that will project some distance for tasks like trail walking.
____Wide Throw: I want a beam with a noticeable hot-center for distance throw and a significant amount of "side-spill". Good for rough trail hiking, search and rescue, and general distance work..
____2 hours + (I critically need this light to run for extended periods in between battery changes/charges).
11) Durability/Usage: Generally the old phrase you get what you pay for is very accurate for flashlights.
____Critical (Police, Fire, Search & Rescue, Caving, Survival).
____I dont know.
____Any size switch will do.
____I want multiple light levels. (Some lights have 5-16 light levels.)
____I want a selector ring.
These are not all needed!
14)Material/Finish/Coating
__I don't mind, but would prefer metal over plastic____.
15) Water resistance
____IPX4 as a minimum
16) Storage conditions
____In house (temperature/climate controlled environment)
Red LED
T
Up to $100
3) Format:
4) Size:
6) Manufacturer:
____I don't care
200-300 lumens
____I dont know.
Red LED
