kj2
For work I'm looking for an ATEX light. Should be safe to use around highly flammable liquid/gasses like gasoline, thinner, turpentine and gas canisters.
2) Budget: An easy question, but you may change your mind after answering the rest!
____I don't know yet
____Up to $25.
____Up to $50.
____Up to $100.
__x_Up to $200.
____Up to $300.
____Essentially unlimited.
3) Format:
____I am not sure, please help me decide.
__x_I want a flashlight (hand held/self contained).
__x_I want a self-contained headlamp.
__x_I want a headlamp with an external pack/power source.
____I want a mounted light (typically for a bicycle or vehicle)
____I want a lantern/area light.
____I want a portable spotlight (it may have an external power source).
____Other ____________________________________________
4) Size:
____MICRO - Keychain size.
____TINY - Every day carry (2-4 inches).
__x_SMALL - Every day carry (4-7 inches).
__x_MEDIUM - Holster/belt ring carry. (>7 inches)
____LARGE - Big enough to need its own travel case.
____I don't know/I don't care.
5) Emitter/Light source:
__x_LED (known for efficiency, longevity, and compactness)
6) Manufacturer:
__x_I want to buy a light from a large/traditional manufacturer that is ready to go out of the box.
____I would like a light from a specialty manufacturer (Possibly limited run/Custom).
____I am interested in assembling my own components. (for example a "host" or flashlight body from one manufacturer, and a "drop-in" emitter from another source).
_x__I intend to use "Primary"/Disposable Alkaline batteries based on the usual AAA/AA/C/D sized cells common to most stores.
_x__I intend to use "Primary"/Disposable Lithium batteries based on the usual AAA/AA/C/D and CR123 sized cells common to most stores (often a cold weather or long storage choice).
_x__I intend to use Rechargeable cells (NiMH or NiCD) based on the usual AAA/AA/C/D sized cells common to most stores.
____I intend to use Rechargeable cells based on less common formats (18500 or 18650 Li-Ion, RCR123, et-al).
____I want a light with an integrated rechargeable battery pack.
____I want to navigate a dark room or read a map (1-10 lumens).
__x_I want an indoor "blackout" light (15-50 lumens)
__x_I want to confidently walk around an unlit/unpaved rural area (60-150 lumens).
__x_I want to illuminate my entire backyard or a campsite (150-300 lumens).
____I want to illuminate an entire field, the neighbor's front yard several houses down, impress my friends and neighbors, etc. (300-700 lumens).
____Not Important (A "night-stand" light).
_x__Critical (Police, Fire, Search & Rescue, Caving, Survival).
____I don't know.
____Any size switch will do.
_x__I need a BIG switch (I'll be using gloves or have very large hands or coordination issues).
_x__I want a forward clicky (Helpful for momentary activation and signaling).
____I want a momentary switch (Predominantly for use with signaling and short bursts of momentary light only).
_x__I want a body mounted switch (near the head, like on a Maglite).
_x__A simple on-off with only one output level is fine for me.
_x__I want 2 light levels. (Brighter/short runtime and Dimmer/long runtime.)
_x__I want multiple light levels. (Some lights have 5-16 light levels.)
14)Material/Finish/Coating
_x__Plastic/composite body (this may limit your choices significantly).
_x__Anodized Aluminum – either type II or III (Hard Anodized) (Aluminum, specifically HA, is the most common material/finish for today's higher end flashlights).
____Stainless steel (durable, but much heavier than aluminum)
____Titanium (durable and nearly as lightweight as aluminum, but can be moderately to significantly more expensive).
15) Water resistance
____None needed
_x__IPX4 (Splash resistant)
_x__IPX7 (Waterproof to 1 meter/30min)
_x__IPX8 (Submersible to greater than 1 meter for 4 hours)
____"Hybrid" light (bright incandescent combined with long running LEDs)
____Pocket/belt clip
____Holster
____Wrist/Neck Lanyard
____Crenulated bezel
_x__Non-sparking, Intrinsically Safe (IS) for use in explosive environments
____Up to $25.
____Up to $50.
____Up to $100.
__x_Up to $200.
____Up to $300.
3) Format:
4) Size:
6) Manufacturer:
____I don't know.
____None needed
____Holster
