Luter
Hi everyone, recently I have found interesting battery, 18650 battery with build in rechargeable port build on the top of the battery, excellent idea i though, and with the good 3400mAh capacity you can't go wrong, the only downside is that it is a bit longer then the standard 18650 battery. It's made by Lumintop and you can easy find them on most of the Chinese online stores.
Despite it's length I like the idea of ability to charge the battery with any 5V usb port. As the length it doesn't fit all of the 18650 flashlight so I build one which will fit it easy, I present you Triple LS with Quick lens change 2.0!
2.0 because the recess for lens is deeper so its easy to change and also the front glass is glued to the crown so you don't need to messy about with o ring and loosen glass.
The light is 129mm long with 30mm dia head and 25mm dia body. 6AL4V titanium waterproof body and pocket clip, reverse switch, 6Amp 22 groups driver and triple XP-G3 4000K 90+ CRI led.
The light will come with the in genius build in rechargeable battery and 3 carclo optics. Price including P&P $800.
