Water Cooled LED Flashlight :)
vestureofblood
Missouri
Hi all,
This is something I've been wanting to experiment with for a while now. I feel like this proves yet again that thermal path is king...
Please let me know what you think of the project.
StarHalo
California Republic
Love the idea, but man is that some ugly implementation; starting with a computer water-cooling kit might make more sense, and look a lot better..
KITROBASKIN
New Mexico, USA
Subscribed!
Maybe someone will build a forced air cooling, compact 2X 18650 XHP70 with maybe 3 inch reflector. I have a ~1.5" biscuit fan blowing on cooling fins attached to the motor on a radio control car (fan purchased from thetoyz.com some time back)...
Lynx_Arc
Tulsa,OK
Just need to make a light that is designed to work in a jar of water.... a water lantern.
StarHalo
California Republic
Do this but with a light source:
rayman
Germany
+1 for the idea with the computer water-cooling solution.
There are already multiple water-cooling systems for different fan sizes and quantities. I like your idea but I think for a longer possible runtime you need to use active cooling for the used coolant. The ice will melt and the water will get hot and then the cooling capability will degress. If you use an active cooling solution you will only be restricted by the amount of batteries you can carry ;-). But in your setup the active cooling system should be easiely integrated.
vestureofblood
Missouri
Subscribed!
Sounds ambitious.
I'll be shopping around....
Overclocker
Philippines
you'll want a jet of water directed at the backside of the MCPCB
you could even try cutting micro-grooves on the copper MCPCB to increase the surface area
