Manker E03H Headlamp XPL CW/ Nichia 219C AA battery is releasing
Manker
Specification:
Emitter: CREE XP-L LED / Nichia 219C LED
Maximum 350 lumens output XP-L CW / 240 lumens output Nichia 219C
Maximum beam intensity: 840cd
Maximum beam distance: 58meters
Working voltage: 0.6 -1.8v
Waterproof: IPX-8, 2 meters under wanter
Impact resistance: 2 meters
Driver: Most efficiency constant current circuit
Material: Aircraft-grade aluminum body
Surface teatment: Premium type III hard anodized anti-abrasive finish
Lens: Toughened ultra-clear glass lens with anti-reflective coating
Magnet tailcap
Dimensions: 78mm length x 20mm head diamter
Weight: 80g (headband included)
Accessories: O-ring *1, Lanyard *1, User manual *1, Pocket clip *1, Filter (white, red, green)
Brightness Levels & run-time:
Moonlight: 0.1lm 175hrs,
Low: 12lm 30hrs,
Mid: 50lm 7.5hrs,
High: 140lm 3hrs,
Turbo: 350-140lm 3min-2.8hrs,
Strobe: 350lm.
Operation:
1.When the flashlight is off, one click, access to moonlight mode (left part of the figure),one click to circle: moonlight - Low - High. Long press for off. 2.When the flashlight is off, long press to access to the mode your last use as in left part of the figure (Memory function), one click for circle. Long press for off.
3.When the flashlight is off, double click access to Turbo, one click for circle. Long press for off.
4.When the flashlight is on, double click to switch between the two groups(left and right part of the figure)
Lock out:
One click-Double-Triple from any mode to lock out the flashlight.(The main Led will keep on shine with an outputof 0.1 lumens for 5 seconds and then shut off)
More information please visit: http://www.mankerlight.com/manker-e03h-aa-headlamp-350-lumen-angle-flashlight-with-headband/
iamlucky13
Thanks! Looks like the perfect step-up from the E02, and I really like the high-CRI option.
Have you tested standby drain?
PaladinNO
Norway
And I who ordered an E02H only yesterday... :mecry:
Ebay, so no return possible.
Wanted a high CRI Nichia 219B / C compact headlamp, but preferably with longer runtime than a single AAA could provide.
But none of the other options ticked so many of my boxes like the - at the time - E02H did.
Guess there's nothing for it then. Gotta order the E03H too. :p
jakehinds
Hey Manker, how come this light has barely any coverage? I feel like it's essentially unknown to most people right now... :( Does it take 14500's? I know the E02 can only run on turbo, and I was really hoping that issue is fixed in this current model. I can hardly find it for sale, but I'm dying to get my hands on one to try out.
ironhorse
Pennsylvania
I received mine on 12/23/17. I have it's little brother the E02 3A version. They are both really nice lights. I have both in the Nichia 219C. The Nichia option is the main reason I tried one and, I am glad I did.
