First Klarus Headlamp Released - 550Lumens Titanium H1A Headlamp
klight
1x 14500 550Lumens
Titanium Triple-Lamp Compact Headlamp
Klarus Titanium H1A ******
--RELEASE---
Whenever both hands are occupied, holding a light source becomes difficult. This becomes the time for the headlamp to shine! Reading maps in the dark, jogging after sunset, or simply getting an early start on your hiking trip, a headlamp gives you more flexibility and convenience. When on the trail and moving fast, having hands free for different tasks, such as carrying luggage, sorting through packs, etc., becomes even more important.
The myriad of options when faced with buying a headlamp can be confusing due to the different choices on the market. Some factors, though, stand out in the top choices: lightweight, compact, long battery life, great output at a distance, waterproof, and more.
After carefully researching the market and consumer requirements, Klarus is releasing the Titanium H1A. An innovative, lightweight, extreme output headlamp with three separate lamps, with a Titanium body, is perfect for those who often find themselves outside, in the dark.
Featuring:
1. Reliable, powerful illumination. High output up to 550Lumens with CREE LED.
2. Aerospace Titanium housing.
Compact Size: 66mm(2.6")x40mm(1.57")x32mm(1.26");
Lightweight, only 73g(2.58oz w/o battery);
Robust, Scratch & Corrosion resistant, Excellent heat dissipation;
Waterproof level up to IPX67.
3. 90 Degrees adjustable illumination with long battery life up to 127hours.
4. Triple-lamp System, optimal beam pattern, patented anti-dazzling design with proprietary lens for greater user comfort
a) Main lamp: Extended range light with fade-in/fade-out function
b) Side lamp (white): Floodlight with Strobe and SOS functions
c) Side lamp (red): Red light with fog penetration, strobe function, protects night vision
5. Lock-out Switch to avoid accidental activation
6. Intelligent Temperature Protection System
7. Intelligent Battery Capacity Indicator. Low battery voltage protection. Reverse polarity protection. Wide battery compatibility (14500 Li-ion battery with Micro-USB charging port included)
8. Headband sweatband with safety reflector
Lighting levels for Titanium H1A:
Specifications and Package of Klarus Titanium Headlamp H1A
Klarus Titanium H1A headlamp, equally at home in the hiking pack, tool bag or around the house. Great hands-free lighting for hiking, jogging, camping, exploring, climbing, riding and even caving, the H1A is also an excellent tool for professionals. For all the plumbers trying to see under a house or sink, mechanics troubleshooting an engine, electricians checking between walls, the H1A is a convenient bright light while keeping hands free to work, anytime and anywhere. When the job needs to get done, put on a Klarus Titanium H1A headlamp, and say goodbye to awkwardly holding a flashlight between your teeth!
More features
about
1x 14500 550Lumens
pls watch the video, thanks.
LightObsession
A couple questions:
1) Why does the picture of the "floody" side white beam have a well defined hot spot, rather than looking floody?
2) Why is the side white light listed as being less than half as efficient as the primary light - less run time at 50 lm than the primary at 100 lm?
klight
A couple questions:
Good questions, thanks.
1) will change the beam to look floody, thank you.
2) because of using different LEDs to the side white light and the primary light.
