DC2 / 18650 Model
okluma
OKC, OK
Okluma now has an official 18650 light, otherwise known as the DC2. It's running our version of the mtn-17dd, Nichia 219cs, and an Omten reverse clicky switch. We've only made a few of them, but expect to have a much larger batch out by December. They'll be available in aluminum, titanium, copper, and brass. All DC2s come with a Sanyo NCR18650GA. Copper and brass versions come with a sapphire lens. Stylish DC2 cigar boxes are on the way.
okluma
OKC, OK
There are a couple different ways to go on firmware for the mtn-17dd. Bistro from Toykeeper is a good option. We're working on our own firmware, but it's not currently programmable.
Yeah, we can definitely put in an H17F.
xdayv
Philippines
Thanks Sir. I would love to put an H17F. ;)
the0dore3524
California (Bay Area)
Feels like you changed the pictures on the website...either way, they look slick. Can't wait till the DC2 is officially released! Time to start saving up.
okluma
OKC, OK
Yeah... We spent some time cleaning up the website so it was less sketchy.
Thetasigma
Michigan, USA
Oh, btw... will an H17F be easy to program via a reverse clicky?
Depends on the person, I personally find programming to be very difficult with a reverse clicky, but YMMV.
Glad to see this come to fruition, congrats Jeff!
staticx57
NJ
I would imagine it is easier. All of the progammable drivers bistro, guppy, crescendo, A6 are better off with reverse clickies.
xdayv
Philippines
Thanks guys. Would this mean full clicks 8 times to enter to programming or 1 full click then half clicks 8 times?
staticx57
NJ
Turn light on. Half press 8 times. While in programming you only half press. You never need to click the light again unless you need to turn it off such as thermal setting.
xdayv
Philippines
Maybe if you don't use the FET channels.
I agree with Devin, I didn't like Luci2 on a reverse clicky. The double click shortcut was particularly annoying
1. Reverse clicky can withstand the FET channels?
2. What particular part of the UI made the double click annoying - is it right after full click? or during the half clicks?
okluma
OKC, OK
It's just different. It was a bit frustrating when you're used to a forward clicky the first few times, but after that it's just as easy.
Would forward clicky be an option ?
Yes, we're certainly going to try and fit the McClicky into the light. I'm pretty sure we can do it, but we haven't done it yet. It's not at the top of the list though, but it is on the list. We will have to drop the output to keep the McClicky from melting.
Yes, the reverse clicky switches will take a lot of current, much more than we're running through them. Personally, I found having to turn the light on first before entering programming mode was annoying at first. But after a few times, it's fine.
archimedes
CONUS, top left
Yes, we're certainly going to try and fit the McClicky into the light. I'm pretty sure we can do it, but we haven't done it yet. It's not at the top of the list though, but it is on the list. We will have to drop the output to keep the McClicky from melting....
Thanks. I'm willing to forego max output, in exchange for momentary actuation.
