2017: fully enclosed fixture A19 LED, >800 lumen?
das_blinkenlighten
I've been searching quite a bit here and on the web because I am trying to find 75W replacement 5000K LEDs which will fit into a tightly-sized A19 enclosed fixture. This is still evidently a tall order in 2017. There are some LEDs that fit the bill, but the rating for fully enclosed luminaires is often not in the product listings. So I figured I'd ask the experts :D
I hope in this thread we can collect information on LED bulbs, A19, greater than 800 lumens, fully enclosed rated for the North American market.
If you have found some, what is the color temperature and CRI, are they dimmable, and do they flicker?
Currently it seems TCP is dominant in this niche. Here is a list of some models I've found which meet my specs. This is by no means an exhaustive list, it's just pasted from what I've found online. With TCP in particular I imagine if there is a color temp missing here it's likely available, I just didn't find it.
TCP Non-Dimmable 9W 4100K A-19 LED Bulb, Enclosed Rated, 850 lm, 80 CRI, L9A19N1541K
TCP Non-Dimmable 9W 5000K A-19 LED Bulb, Enclosed Rated, 875 lm, 80 CRI, L9A19N1550K
TCP Dimmable 9W 4100K A19 LED Bulb, Enclosed Rated, 850 lm, 80 CRI, L9A19D2541K
TCP Dimmable 9.5W 3000K A19 LED Bulb, Enclosed and Wet Location Rated, 825 lm, 82 CRI, LED10A19DOD30KW
TCP Dimmable 10 Watt 5000K A-19 LED Bulb, Enclosed Rated, 850 lm, 82 CRI, LED10A19DOD50K (wet location too?)
TCP Dimmable 15W 2700K A-19 LED Bulb, Enclosed Rated, 1600 lm, 80 CRI, L15A19D2527K
TCP Dimmable 15W 3000K A-19 LED Bulb, Enclosed Rated, 1625 lm, 80 CRI, L15A19D2530K
TCP Dimmable 15W 4100K A-19 LED Bulb, Enclosed Rated, 1650 lm, 80 CRI, L15A19D2541K
TCP Dimmable 15W 5000K A-19 LED Bulb, Enclosed Rated, 1675 lm, 80 CRI, L15A19D2550K
Satco Dimmable 9.5W 3000K A19 LED Bulb, Enclosed Rated, 830 lm, 80 CRI, S9836 9.5A19/OMNI/220/LED/30K
Satco Dimmable 9.5W 3500K A19 LED Bulb, Enclosed Rated, 845 lm, 80 CRI, S9837 9.5A19/OMNI/220/LED/35K
Satco Dimmable 9.5W 5000K A19 LED Bulb, Enclosed Rated, 900 lm, 80 CRI, S9839 9.5A19/OMNI/220/LED/50K
Green Creative Non-Dimmable 9W, 120-277V 4000K A19 LED Bulb, Enclosed Rated, 860 lm, 80 CRI, 9A19G4/840/277V
Green Creative Non-Dimmable 9W, 120-277V 3000K A19 LED Bulb, Enclosed Rated, 820 lm, 80 CRI, 9A19G4/830/277
Honeywell Non-Dimmable 10W, 5000K A19, "indoor lighting applications and outdoor enclosed fixtures," 1050 lm, 82 CRI, A197550HB110
Maxlite Dimmable 12W, 2700K A19, LED enclosed omni A-Lamp, 1100 lm, 92 CRI, E12A19DLED927/JA8
Maxlite Dimmable 12W, 3000K A19, LED enclosed omni A-Lamp, 1100 lm, 92 CRI, E12A19DLED930/JA8
The Maxlite products don't appear to be targeted at consumers, and are typically sold in large quantities, which is unfortunate because that CRI is sooo appealing.
I have not been able to confirm which, if any, of the many Feit Electric offerings are suitable for use in enclosed fixtures.
mcnels1
Those Maxlite bulbs are listed at topbulb.com: https://www.topbulb.com/product-brand/maxlite/maxlite-led-lamps/maxlite-a-lamps?watts=30023
Bulbs.com has the best bulb search filtering of any retailer I've found, but didn't come up with anything outside your list.
I bought some Feit Electric LED bulbs (CEOM60/927) that are rated for enclosed fixtures. The two I put in an enclosed fixture that stays on for an extended time both died almost simultaneously within a year. Another two in an enclosed fixture on a motion sensor are working fine after 1 1/2 years.
My house has about a dozen enclosed ceiling fixtures designed for for two 60-watt incandescents, so I'm very interested in enclosed-rated bulbs. I have had Switch Infinia bulbs in several for at least 3 years, but I can't get any more :-(.
beatus
I tried their bulb before, and it's good from my point of view, and will see then, and we expect a led to work at 5 years, this is just begingin.
