LED Suggestions for 3D mag host.
mdhammack
Houston TX
I have a 3D mag host I had intended on building a mag85 Hotwire with but since those bulbs have nearly dried up I'm looking for suggestions for an led setup. I already have a 9AA pack I would like to use for this. I also have a spare UCL and aluminum MOP reflector for it. This will be an occasional use light that I will carry in my truck. Open to ideas guys. I know little about the high performance LED's as far as output and run times that could be expected from this setup. Honestly I would prefer to send it to someone for the mod but would like to know what to ask for. Thank you for your time and ideas
fivemega
California
You can use following bulbs and batteries in 3D M*g:
G4 Bi-pin FM1909 (11V, 5.5A) $16 Each (Use 3 IMR18650)
G4 Bi-pin WA01331-U (9.6V, 2A) $10 Each (Use 9 Eneloop or 3 protected)
G4 Bi-pin WA01318-U (9.6V, 2A) $10 Each (Use 9 Eneloop or 3 protected)
Potted WA01321-U (8V, 2.3A) $12 Each (Use 8 Eneloop)
You can also use 3 XML drop in if LED is preferred.
mdhammack
Houston TX
Thank you Fivemega! I haven't been around the scene for 3-4 yrs now and didn't know where to begin looking for new bulbs. The 1318 and 1331 are super simple for me as I already have one of your bi-pin adapters. The 1909 is your bulb collaboration if I remember correctly?? I may have to try all 3 I've even got an old 2D host I can bore for 8 cells to try the 1321.
