Simple is better! Critical need for single mode, AA powered, light for walking
J.J.H.
Hi folks!
I currently carry a Sunwayman V11R most of the time. I love that little light! However, I have some developing needs, so I think it is time to get something more suited to a particular use-case.
Heres the deal: I have an injured cerebellum, and this makes navigating in the dark somewhere between difficult and impossible! So any time I am out at night, unless I am on a well-lit level street, I am using a flashlight. As you can imagine, my light is a truly critical part of any evening out of the house. While my current EDC is a great little light, I would like to have something for walking around with that is 1) bright 2) wide-beamed, 3) runs on one, or possibly 2, AA batteries, and 4) has NO modes! Just on and off!
Maybe this kind of simplicity doesn't exist, but if you have recommendations, let me have em! I am willing to spend a bit, so budget isn't a primary consideration, but I would love to not go flat broke buying a little light, so be reasonable.
I have filled out the checklist below to be as specific as possible, but I have mentioned the really crucial stuff.
Thanks so much!
-JJH
(EDIT: I know my hope and dreams re: batteries and output are a stretch. I want alkaline because I can buy them everywhere and I have to be able to make this thing run in a pinch by stopping into a gas station. So maybe 2 AAs is more likely!)
____This will be mail-order or Online (location mostly doesn't matter, but I am in Canada...).
2) Budget: An easy question, but you may change your mind after answering the rest! :)
____Essentially unlimited.
3) Format:
]____I want a flashlight (hand held/self contained).
4) Size:
____SMALL - Every day carry (4-7 inches).
5) Emitter/Light source:
____LED (known for efficiency, longevity, and compactness)
6) Manufacturer:
____I want to buy a light from a large/traditional manufacturer that is ready to go out of the box.
____I would like a light from a specialty manufacturer (Possibly limited run/Custom).
____I intend to use "Primary"/Disposable Alkaline batteries based on the usual AAA/AA/C/D sized cells common to most stores.
____I want to confidently walk around an unlit/unpaved rural area (60-150 lumens).
____Wide Flood: I want a defined flood area for semi-close tasks like after-dark campsite tasks or working on a car.
____Narrow Flood: I want a sharply defined flood area that will project some distance for tasks like trail walking.
____Less than 5 yards/meters (looking for something inside a dark shed/garage/basement)
____5-20 yards/meters (check out a noise in the backyard)
____90-120 minutes (Runtime is moderately important, but still not critical)
____Critical (Police, Fire, Search & Rescue, Caving, Survival).
____I need a BIG switch (I'll be using gloves or have very large hands or coordination issues).
____I want a forward clicky (Helpful for momentary activation and signaling).
____A simple on-off with only one output level is fine for me.
14)Material/Finish/Coating
____I don't care.
15) Water resistance
____None needed
____IPX4 (Splash resistant)
16) Storage conditions
____In house (temperature/climate controlled environment)
____Recessed tail switch, but this is not crucial
Modernflame
Dirty Dirty South
I would recommend a Malkoff M31 module with the VME head and the MDC 2x AA body.
This would tick all of your boxes nicely, I think. Single output. ON/OFF only. Common alkaline compatible. The cool white version will give you about 280 lumens. A warm white version is also available, if you prefer. It's more or less indestructible.
If you decide later that you want other battery options, you can use the same emitter/head combination with the 1 x AA body or the 1 x CR123 body
Oh, and the tail cap is recessed.
Tusk
Streamlight's Protac 1L-1AA can easily be set to high only. It works fine on AA, really well on Eneloop's, great on L91's and can take CR123's without an adaptor. It's on sale now a Primary Arms for about $30.00. It's my EDC.
J.J.H.
Malkoff is a great recommendation. I think I will go with exactly this setup, but I sent off an email to Gene anyways to ask for his input before I place an order.
Thanks! -JJH
Keitho
CO, USA
Here is an off the wall idea...the Zebralight SC 53c. If you are able to do multiple clicks one time to set up the programmable modes when you first get it, you can set all of the modes to the same output. So, you'll have a single mode light, one click on, one click off, at the exact level you need for your desired runtime and power. Zebralight drivers are arguably the most efficient made, especially if you don't use the very highest level. They'll work with alkaline in a pinch, but eneloops will perform a lot better.
I'll throw in two options you didn't request. First, would a headlamp make walking easier (hands free)? I use my headlamps either around my head or neck with floody versions to good effect. Second, you might consider 18650 if you're concerned about runtime. At similar brightness levels, they are at least 2.5x the runtime (the equivalent of carrying almost 3 AA, all the time).
Best of luck with your rehab--you've got a large community here willing to support you!
LightObsession
Coast HX5 with adjustable focus. Very easy to use, will tail stand and has momentary activation.
The adjustable focus is very handy to change from distance to close up lighting.
PaladinNO
Norway
Just to throw in some names here (blatant copy from my own lights list) that I bought myself for this very purpose:
Streamlight 88853 Poly-Tac, 130 Lumen, 2x CR123 / 1x 16650 (old version - new version got ~275 Lumen or so)
Coast PX25, 208 Lumen, 3x AAA
Fenix E21, 154 Lumen, 2x AA
