Best 3" LED cube brand for off-road and fog lights
Status
Not open for further replies.
zimm
Virginia
Alaric Darconville
Stillwater, America
I'm currently running Lifetime LED 3" cubes for off-road lighting. Specs: https://www.lifеtіmelеdlіghts.com/led_lights/led_cube_phantom_sun_3_led_cube_light
They're cheaper chinese lights and the finish is fading badly.
If the finish fading (that is, if it's the purely-decorative finish, not a functional finish like on a reflector or the lens) is your only qualm with a purely off-road lamp, do you really need to spend money to replace them?
I also want to buy another pair of cubes to use as fog lights.
Fog lamps, on the other hand, are on-road lamps. You can't just take a general-purpose "work light" or an "off-road light" and wish it into a fog lamp. Take the money you saved not replacing those off-road lamps and spend them on some real fog lamps.
You could build a cube out around these (#0553733) and get in a rectangular prizm about 5.25" tall, and 4.5" wide. You could also go with these. Sure, that's a little larger than you wanted but when it comes to function v. form, function is better.
zespectre
Lost in NY
If the only issue is a fading finish, mask them off well and coat them with spray on truck bedliner.
I've done that with my Jeep and it looks great and is very durable.
Agree w/Alaric that you really shouldn't just slap any random light on as fog lamps. That's a fast road to some pretty hefty tickets if the cops target you. Stick with DOT-SAE like KC Highlights or Rigid.
Alaric Darconville
Stillwater, America
They'll ignore just about any light, it seems. Some will know what to look for and what they're doing, but a ticket isn't the primary worry-- it's safety. Using NOT-fog lamps as fog lamps is deleterious to safety. Using not-road lamps as road lamps is deleterious to safety.
It's more of a fast road to running off into a ditch or making excessive glare for the driver or other drivers-- or if there is a wreck someone could pin it on the wrong lamps being used and contributing to the accident.
You might notice I didn't offer KC or Rigid as lamps as worthwhile brands.
-Virgil-
As it has already been pointed out, that's not how this works. We don't get to choose just whatever random thing to "use as a fog lamp". Anything other than an actual fog lamp is...not a fog lamp! Fog lamps have very specific, particular output characteristics defined by SAE standard J583 and UN Regulation 19. There are some LED cubes that are offered in what is claimed to be an SAE-compliant fog lamp, but in reality a fair number of them don't even come close to being an actual fog lamp.
What do you plan to use fog lamps for? Many people treat them as always-on accessory lights, but that's wrong, too; in reality fog lamps are basically useless (at best) to the majority of drivers in the majority of situations. Detailed writeup on the how-and-why of it here.
If you do actually have a real need for fog lamps, Alaric is right not to recommend KC and Rigid "fog lamps", and while zespectre's advice is obviously well intentioned there is no such thing as a "DOT fog lamp", and neither DOT nor SAE approves lamps of any kind. Whoever advertises or promotes a fog lamp as being "DOT approved", "DOT/SAE approved", "SAE approved", "DOT legal", etc, either doesn't know what they're talking about or they're lying.
zespectre
Lost in NY
So why does Virginia law specifically tell inspectors to "fail if"...
"1. Lamps are not of an approved type (DOT or SAE-P2, P3, PC), or do not comply with subsection A of this section."
https://law.lis.virginia.gov/admincode/title19/agency30/chapter70/section570/
Not trying to be snarky, I'm trying to learn if I have had bad info all this time.
If DOT and SAE don't codify lights then who does?
-Virgil-
P2, P3, and PC are nothing to do with fog lamps; those are marker and clearance lamps. But I see what you're asking. "Approval" in that line refers to lamps the State of Virginia accepts, which has been irrelevant since 1968. Prior to that time, each and every vehicle lighting device -- every brake light, every turn signal -- had to be approved by each and every state. It was a big, expensive hassle that ended when Federal Motor Vehicle Safety Standard 108 took effect, because the law that set up the Federal Motor Vehicle Safety Standards holds that States are not permitted to enforce their own standards more stringent than the Federal standard that applies to a vehicle or item of vehicle equipment. That means states are not allowed to pick and choose which Federally-acceptable items of vehicle equipment they will or won't allow on vehicles registered in that state. That's a very, very good thing, because many states have vehicle lighting codes that are a mess of poorly-written, extremely obsolete text; Virginia's is one of the worst (Dan Stern passed around a running-commentary analysis of Virginia's vehicle lighting code a number of years ago. I thought I'd kept it, but I'm not finding it; if you're interested, write and ask him.) If Virginia's vehicle equipment code hadn't been rendered null and void by the Federal standard, exactly zero percent of the cars presently on the road would be legal, because they all have headlight bulbs producing more than 32 candlepower (and a whole bunch of other stuff not allowed by VA's antiquated code).
The issue at hand is "approval". What I was pointing out to the OP is that "DOT approved" and "SAE approved" don't mean anything on any lamp, and "DOT" on a fog lamp doesn't mean anything.
SAE is not a regulatory body and has no means or authority to approve anything. SAE just issues technical standards, supposedly representing the best practices in whatever the standard is about (fog lamps, turn signals, headlamps, etc). These technical standards do not have any force of law, except to whatever degree a political entity adopts them. The Federal Motor Vehicle Safety Standards incorporate some (but not all) provisions of some (but not all) SAE technical standards for vehicle lights, and while SAE standards are updated periodically, every four to six years, these updates are not automatically acknowledged by NHTSA, the agency within the federal Department of Transportation responsible for the Federal safety standards. If you read the Federal lighting standard, you'll find it contains numerous references to very old versions of SAE standards, going far back into the '60s. That's a shame, but those are the provisions that have the force of law.
There is no such thing as "DOT approval". NHTSA and DOT are not legally empowered or authorized to approve vehicle equipment; that's not how the American system works. Instead, the responsibility lies completely with the maker or importer of the equipment. The "DOT" marking on a headlamp does not mean DOT or anyone else has approved it, it means the manufacturer or importer has decided the headlamp meets all the legal requirements. "DOT" on the lens is the maker/importer's own assertion, or certification, that the headlamp complies with the law. There is no particular pre-test required; lamps do not have to be sent in to the DOT or anyone else before the marking can be applied -- the maker does whatever they feel is necessary to satisfy themself that the lamp meets the standard. Reputable companies put their lamps through rigorous tests. Shady companies laugh and put "DOT" on the lens, gambling (often a winning bet) that their lamps will never be checked out formally. If an investigation is carried out and a headlamp marked "DOT" is found to be noncompliant, NHTSA can force the maker/importer to issue a recall and can issue penalties in the form of fines. Very steep fines, assessed on a per-violation basis, with each sold headlamp counting as one violation. But these enforcement actions are rare, and even when they do happen, the target is often a slimeball "company" consisting of not much more than a warehouse for unloading and stocking containerloads of pretend-headlamps from China, and a marketing department to promote them. Get smacked with penalties? Declare bankruptcy, disappear for a week, open up shop under a new name, continue business as usual.
You'll notice I've been talking about headlamps for the last paragraph or two. That's because headlamps are the only lamps required by law to have a "DOT" marking, and therefore the only lamps on which "DOT" actually means anything. There's nothing stopping anyone from marking other lamps "DOT", but it means whatever the maker decides it means, which could be anything from "It means this lamp meets the applicable provisions of Federal Motor Vehicle Safety Standard 108 as they appeared in the official legal text as of the date the design was locked in for production" all the way to "It stands for Dogs Over Tampa".
You'll frequently see "SAE" followed by letter/number codes, followed by a 2-digit year code, on many vehicle lamps. These markings aren't legally required, but they're allowed, and they mean that the maker says the lamp meets the requirements put forth for [whatever function codes are present] as of [whatever year is listed]. For example, you might find "SAE AI6RSTP2 97" on a multifunction taillamp. There's a breakout chart of the SAE codes on this page which explains what all those codes would mean. But it still doesn't mean or imply anything about anyone's approval.
Fog lamps are not regulated Federally, so states are free to regulate them however they wish, from no regulation at all clear on up to no fog lamps at all (not allowed to be used in that state). Front fog lamps can be marked "SAE F [year]" or "SAE F3 [year]" -- there is no legal requirement for any such marking, though some states say you can only have fog lamps with an SAE marking.
As you can see, it's more complicated than it seems on its face, and the lighting aftermarket's many scam artists are safely betting that most people will think "DOT Approved" or "SAE Approved" or "SAE/DOT Approved" is some kind of a meaningful assurance.
SubLGT
Idaho, USA
https://www.truck-lite.com/content/news/sae-vs-dot-truth-about-lighting-regulations
There is a great deal of confusion regarding lighting regulations in the industry. One common mistake is using the term "DOT approved." The United States Department of Transportation is not an approval agency and will not approve products. In the past, USDOT has sternly warned manufacturers that claim that their products are "DOT approved;" the correct language is "DOT compliant."
Apparently, DOT has stopped issuing stern warnings?
Hilldweller
Hog Waller, GA
For offroad lights, Bajas are the brightest sons of guns I've seen in person. Painfully bright.
I personally believe in cheap-n-stinky for offroad lights since I usually hit a tree or something with them... But, if you gots the budget, Baja will take your money and you'll have godlights.
Rigid makes some better legit lights since being acquired by Trucklite. These things are decent foglights and won't hurt anybody coming at you: https://www.rigidindustries.com/led-lighting/504813
Their regular D series lights will hurt people.
My preference for LED fogs is JW Speaker still. https://www.jwspeaker.com/products/categories/fog-lights/
I've been running a set for almost 4 years and they work great. We get some peasoup fog here in rural GA ---- had some yesterday and today, in fact. And when I'm picking my way to the gym at 3:30 a.m. I'm very happy I have these lights.
Happy shopping, zimm.
Alaric Darconville
Stillwater, America
We'd rather recommend non-toys for use on vehicles.
From SuperBrightLEDs
This DOT-Approved LED Fog Light
There's no such thing as DOT approval. If they're not informed enough to know that, they're not informed enough to produce a quality lamp. This isn't the same as "if a medical doctor doesn't know who won the Boston Cup in 1978, they're not informed enough to be a doctor". Knowing how the lighting laws in the USA works is intrinsic to the business of making and selling vehicle lighting.
Also, in the U.S., fog lamps are not Federally-regulated vehicle lighting with one exception: They are listed as impermissable as DRLs. (Aside from that, there are references to them including that turn signals must be spaced from them depending and low-beam headlamps and auxiliary lamps, depending on whether they are of a reflector type or non-reflector type, but this part of a requirement for turn signals.)
Spiderman302
Most people are woefully ignorant of the "DOT approved" vs "compliant". Yes, DOT does not apply to fog lights as you have pointed out.
just because the vendor does not know, does not make it a bad product.
I was focusing on the fact that this light has the "prefect" beam pattern for a fog light, flat, wide and NO glare! With 14 watts it is sufficiently bright and not over the top. I have a pair on my bike and they work very well. Last week I was on PCH in the fog and I could see the beam pattern. Very nice....
Alaric Darconville
Stillwater, America
When the vendor is the manufacturer, it's something they need to know.
I'd love to see a copy of the photometric test results!
Electrical consumption is not a measure of light output, let alone the light's pattern. Perhaps you meant to say that despite the power consumption, they *seemed* to produce enough light-- but again, there's a specific beam pattern and specific minima and maxima for the light output that makes a good fog lamp a good fog lamp, a bad fog lamp a bad fog lamp, and a NOT fog lamp a NOT fog lamp.
Alaric Darconville
Stillwater, America
If that's a pic of ONLY the light from that lamp, check out the huge source of specular glare for other drivers and even for the rider. That's right in your foreground.
Beam shots usually can't tell us how *good* a lamps is, but they often tell us how bad one is.
Also, at that distance that's not a very wide beam, which a fog lamp must have. It's not for forward seeing, it's for seeing the lane and edge markings to help you stay in your lane at a craw.
no glare for on coming traffic and no close in glare for the driver. It is a win- win.
Well, no-- lots of specular glare for everyone.
-Virgil-
https://d114hh0cykhyb0.cloudfront.net/images/uploads/fog-cw25w-target.jpg
Do note that there is both an upper cut off and a lower cut off. So all the light goes to the horizon where it will do the most good.
That is not an accurate description of what we're looking at here...
it creates no glare for on coming traffic and no close in glare for the driver. It is a win- win.
...and that is not an accurate claim for what this lamp does (and doesn't do).
Status
