I'm building up a S2+, and wanted to try the offerings from LED4power. Purchased their LED tailcap as well, but I can't check that until everything else is in place.
Board is the 3xp mosled, and using the LD-B4
My first attempt on reflowing XPL-hi's onto the board ended in failure, and a week's wait for new LEDs to come in. I did buy two boards, because I've only ever done one other reflow.
The question is, shouldn't the negative side be linked with the neg pad of the LED's? I can see the positive is fine, but I don't want to waste another board and round of LEDs experimenting.
I made a quick video, does this look correct?
https://youtu.be/QEcktq-Xies
I am putting the notched end of the LED on the dotted section of the LED pad on the board
*edit: better image of the LED board and driver
