HKJ
[size=+3]Keeppower 18650 3000mAh P1830R (Black) 2017[/size]
Official specifications:
This is a high current protected 18650 cell from Keeppower
Very good tracking in the discharge curves.
The cell gets rater hot at 15A
At 20A I stopped the test due to temperature.
This test only goes to 15A and did not trip the build in protection.
Protection will usual trip on 3 conditions: Over current, over charge and over discharge.
[size=+3]Conclusion[/size]
This is a good cell, but the build in protection do not trip on overload (It will probably trip on higher currents).
[size=+3]Notes and links[/size]
The battery was supplied by Keeppower for review.
How is the test done and how to read the charts
How is a protected LiIon battery constructed
More about button top and flat top batteries
Compare to 18650 and other batteries
- Part No.: P1830R
- Protected 18650 Li-ion Rechargeable Battery
- Minimum Capacity: 2900mAh
- Typical Capacity: 3000mAh
- Normal Voltage: 3.7V
- Maximum Continuous Charging Current: 5A
- Maximum Continuous Discharging Current: 15A
- In Built Safety Circuitry
- Protection Circuit (Against over charge, over discharge, over current and short-circuit.)
- 4.20V maximum voltage and 2.50V cut-off voltage
- Over 500 charge-discharge cycles
