Light Review: Streamlight Super Siege Lantern
subwoofer
Hove, UK
In its first incarnation, the Siege lantern was a full size D-cell powered light, shortly followed by the cute Siege AA (you guessed it, powered by AA-cells). But not yet finished, Streamlight have taken the lantern to another level with the Super Siege, which now features a built-in rechargeable battery and USB power bank function, along with an essential glare-guard for task lighting - it certainly is the Super Siege.
Taking a more detailed look:
Aimed at attracting people in a retail store, the box is a semi-exposed 'try-me' type.
In the box we have the Super Siege, its glare guard, mains power adapter and a set of three plugs for it (US, UK and European), plus the instructions.
On the glare guard it tells you to give the Super Siege a full charge to disable the 'try-me' mode.
A Streamlight mains power adapter, which presumably also works with other rechargeable models as it tells you not to use it with the Alkaline Waypoint.
I need the UK plug, so here it is.
The mains adapter itself has a set of two contacts and a rotary connector for the plug. There is a release lever to allow you to easily swap over the plug type as and when needed.
Ready to go with the plug fitted.
Wrapped round the Super Siege is a large carry handle and hook that lifts up.
There is also a much smaller hanging clip incorporated into the top. This clip allows for a more secure attachment and keeps the light as high as possible.
Flipping the lantern over, and there is an identical hanging clip in the bottom.
The hanging clip in the bottom makes more sense when you see that the diffuser for the main light can be removed exposing the protective dome over the Super Siege's LEDs.
In the middle of the LED board is a white XM-L2 LED and round this are four red LEDs.
There is a single power switch on the Super Siege which also acts as an indicator light for both charging and using the light. Underneath that switch is a rubber protective cover hiding the charging port and USB power output.
Lifting aside the port cover to show the charging port and USB power output.
Fitting the glare guard to the lantern's diffuser makes the light output directional, and it covers just over half the diffuser.
(Wherever you see the 'Read MORE' marker, it indicates that the Extended Version of the review has additional content at that point. Viewing the extended version helps support further reviews, but please ensure you return to this Forum for comments and discussion.)
When charging the switch lights up red.
On reaching full charge the switch turns green.
Not to be forgotten is that the base has a concealed storage compartment. Twist off the bottom to access this.
The beam
First up here is the White output with the standard 360 degree lantern beam. You can see the excellent wash of light, but also very clearly the thing I hate about lanterns, terrible glare.
Fit the glare guard and now we are talking. Obviously the total output is cut quite drastically, so it might be better in some cases to position something between you and the lantern, or hang it above your head, but if you are using it as a work light, this becomes ideal.
Modes and User Interface:
All controlled via the single power switch there are three White Output Modes, Low, Medium, High, and three Red Output Modes, Low, High and SOS.
To turn the Super Siege ON briefly press the power switch. This will turn on to the last used constant output level (White or Red).
To change output level / mode, briefly press the switch again within 1.5 seconds of the last press. This will cycle through the available modes all the way to OFF.
If the Super Siege has been ON a mode for more than two seconds, one brief press of the switch will turn the light OFF.
To change the colour from White to Red, or Red to White, press and hold the switch for two seconds.
The USB Power Bank function will automatically start when a suitable device is connected. During charging the switch will light up to indicate the status of the battery. Green means full power, then the switch turns yellow, then red and finally flashing red when the battery is getting low.
Batteries and output:
The Super Siege runs on its built-in battery.
___________________________________________________________________________________________________________
Super Siege using built-in cellI.S. measured ANSI output LumensPWM frequency or Strobe frequency (Hz)
White High11091000
White Medium550256
White Low158256
Red High70
Red Low20
There is parasitic drain but it cannot be measured due to the construction of the light.
A very impressive performance on High for both the maximum output and the runtime. The specified ANSI output value is achieved, and the output does not drop below 600 lumens for over four hours. Finally, at not far off five hours, the Super Siege runs out and shuts off.
Troubleshooting
This section is included to mention any minor niggles I come across during testing, in case the information helps anyone else.
The Super Siege in use
Lanterns were the first safe and convenient portable source of light. Although they have undergone many changes, the lantern has retained essentially the same appearance and function of area lighting. Just like the original Siege lantern, the Super Siege is a full size lantern, equivalent to most traditional lanterns. It is for those uses where size and weight are not an issue, if that is a priority, the smaller Siege AA becomes a good bet, but lacks the power and features the full size lantern gives.
The Super Siege uses its technological advantages to make it so much more than a portable area light. One of its first key features is so simple and could easily have been added to any lantern - the glare guard. For me this is one of the most critical features, and where I would normally avoid lanterns due to their glare, now I'm picking the Super Siege for all sorts of jobs.
As well as the full lantern and the task light configuration, the diffuser can also be removed to expose the LED dome cover, so you can run the Super Siege with fully exposed LEDs giving the ultimate in flood light. This however has extreme glare and only really works when hung up overhead. With the diffuser removed, the Super Siege is also much smaller. But beware, if you might need the Super Siege's ability to float, it will only float with the diffuser fitted as this provides enough trapped air to give it sufficient buoyancy.
There are two aspects of the Super Siege that do not work that well. The switch illumination is very bright, and if using the low red output, the switch glows as brightly as the red LEDs do. This is very distracting and means that if you want a dim red light to maintain your eyes dark adaptation, you will find a bright green light shining out from the switch. This also impacts on the USB powerbank function, but more on the in a moment.
The second aspect, which I'm very disappointed to still see is the use of PWM. Especially in a lantern which floods the entire area with light, on the medium and low output levels, you see very obvious strobing effects when moving...at all. Please Streamlight, can you use current controlled output and not PWM?
The compartment in the base is an odd shape, but is useful for keeping a few things in. If nothing else you can keep a USB cable for charging various devices in this compartment.
And on the subject of the power bank feature, this is very useful in these days of so many devices that can be charged from USB. What you must consider however, is that any power you use to charge a device, be it phone, tablet, e-reader etc, is power you rob from the lantern's light output. So be careful you don't find yourself in the dark because you charge your phone up. What is a bit of a pity is that the Super Siege needs a 12V power adapter to charge it when the typical power bank these days is also chargeable via USB.
During use of the USB power bank, the switch illumination goes from green to yellow quite quickly. Watching the accumulated Wh delivered, the switch goes red after around 15Wh have been output, so there is still 40% battery left once the switch turns red. In fact the flashing red indication starts relatively soon afterwards. If I needed the Super Siege for light, I would definitely stop USB charging once the switch illumination turns red, as you at least know there is 40% left.
Ideal for camping, fishing and to have in a shed/loft or other unlit out-building. Altogether the Super Siege gives you a nice rounded package of features all of which are genuinely useful and not a gimmick.
Review Summary
Things I likeWhat doesn't work so well for me
Powerful 1100lm output.Uses PWM on all output levels.
USB power bank.Using the power bank reduces LED output runtime.
White and Red light output modes.Needs 12V power adapter to charge.
Glare-guard included for task lighting.Output cuts out completely when the battery is low.
Storage compartment in base.
Floats (as long as the main diffuser is fitted).
(Moderators, there is a reciprocal link at the end of every review on Tactical Reviews.)
UnderPar
Philippines
Wow! Great review , as ever, SW. You've always impressed me on how you do your reviews and continuously improving. Thanks for sharing.
delus
Pittsburgh
A light with the ability to float is extremely important to me. I'm happy to report that both of my super-siege lights have performed very well in this regard. They both have been in the drink more than once and the inside of the diffuser has had no droplets at all. The diffuser locks down very tight. The rubber cover for the charge ports has also performed well underwater, but whenever it gets near the river I always use an extra safety step and tape the cover down. (it's not like I'm gonna be charging it on a canoe.)
The multiple tie-down points are also very good, as long as you remember to actually tie it down. I thought I had lost one of these, but found it happily spinning in a pool 12 hours later and five miles downstream, undamaged. It had gone over some class II rapids. Even the glare guard had not popped off. The name is STREAM-light, is it not?
Toss a rope over a tree limb and lift it up, it illuminates an area big enough for four tents. More than enough battery to last all night every night for a seven day trip, if you keep away from high mode. What's the runtime in red mode? weeks? High mode is always there if you need it.
For me, it's perfect. I don't know what more I could ask for.
vadimax
Vilnius, Lithuania
The only improvement I might imagine — is remote operation in case you hang it high enough to not be operated manually :)
Modernflame
Dirty Dirty South
I didn't know these things existed until I spotted one in an outdoors shop this afternoon. Digging the AA version. Now that I've read a proper review, I'll pick one up. Thanks!
LEDAdd1ct
Hudson Valley
How difficult is it to gain access to the internal battery to remove it?
If the lantern was never meant to be *cough* hacked *cough* and disassembled—
How much glue/epoxy is in the way of cracking this open?
subwoofer
Hove, UK
If I ever explore that aspect further I'll post an update, but currently have no plans to break it open.
subwoofer
Hove, UK
can the light be turned on while charging?
Yes you can. If it has been run down to absolutely nothing, it sometimes won't turn on straight away, but if there is some charge, it will run while on charge.
