Hi all
Recently i've encountered some weird case in relate to LED strip dimming, a summery of the case as below:-
1) LED Strip installed inside a decorative lighting
2) Runs on Lutron 1-10v dimming signal
3) One section of LED strip starts to flicker only after its adjusted to 50%
4) Swap that section of LED strip to other proper working module's driver, problem remain the same
problem is, theres a flicker at the output voltage causing the flicker, when i wire the load to any other driver, when other load works perfectly fine
Wonder if anyone encounter this before?
