Jetbeam USB Type C Fast Charging Headlamp HR30 is coming
Jetbeam5
Shenzhen, China
Hi All,
Good News!
Jetbeam USB Type C Fast Charging Headlamp HR30 is coming.
Features
  • A light-weight and high-performance headlamp mainly designed for hiking, climbing, camping and construction operation
  • Utilizing a Luminus SST40 N5 LED with a lifespan of 50,000 hours
  • Convenient single switch allows illumination mode (5 levels) plus red light alert mode
  • Max output of 950 lumens and throw distance of 120 meters
  • Powered by 1*18650 Li-ion battery and compatible with 1*20700 (unprotected) or 2*CR123A (charging for headlamp is prohibited)
  • USB type C fast charging
  • Power indicator function to know power level at any time
  • Reverse polarity protection to protect from improper battery installation
  • 160° rotatable mechanism to adjust beam angle for different applications
  • Removable bracket design
  • Versatile with a clip and tail magnet function
  • Made of durable aero-grade aluminum alloy
  • HAIII military grade hard-anodized finish
  • Toughened ultra-clear mineral glass with anti-reflective coating
  • Waterproof rating: IPX-7 (1 meter under water)
  • 87 mm (L) * 44.5 (W) *46 (H) and 105g without battery
Specifications
LED: Luminus SST40 N5
Maximum output: 950 lumens
Reflector: Coated metal reflector (OP)
Glass: Coated mineral glass
Body material: Aero grade aluminum alloy
Finish: HA III military grade hard anodized anti-abrasive finish
Battery: 1*18650/1*20700 (unprotected) /2*CR123A (charging for headlamp is prohibited)
Switch: Single side switch
Length: 87mm
Head:Φ46mm
Tail:Φ44,5mm
Weight: 105g (excluding battery)
colight
On Earth
Re: 【New release】Jetbeam USB Type C Fast Charging Headlamp HR30
I have to say that this headlamp very closely resembles the HL55 and HL60R from Fenix!
Jetbeam5
Shenzhen, China
Hi Colight,
Comparing with HL60R, Jetbeam HR30 is with USB Type C Fast Charging port and it has tail magnet function.
colight
On Earth
Oh yeah, that's very reassuring...... :thumbsdow
