7ah SLA replacement
BVH
CentCalCoast
Certainly can. And check the label on your ballast. Some can take 18 Volts input and if that's the case, you could use a 4S/5500 and have just about the same Watt Hours and run time. Hopefully, you have a balancing charger to charge these type of Lipo packs. And I find they do have a self-discharge rate but not nearly as fast as an SLA.
