Paracord wraps for mini lights - easier on the teeth
Guitar Guy
West Virginia
Finally got time to ditch the black duct tape and put some cord on these. Hollowed out 550 paracord on the E15, and hollowed out 3/32" 4 strand on the E05. 100% natural hemp cord on the tails, but probably going to ditch the tails or tie something better.
Very satisfied with both lights, and the hollowed out cord flattens out nicely.
[/IMG]
Guitar Guy
West Virginia
Thanks Scout. The cord is wrapped very tightly over the ends, so that it holds itself together without coming loose. There are several steps involved to achieve this, but hard to describe without a pictorial tutorial. I got the knotless wrap from a book, but there may be online tutorials available. It does take a little practice.
This is what the tucked ends look like on the underside.
[/IMG]
eh4
Try the clear poly tubing that you can get for pennies per foot at a hardware store, it rebounds, doesn't have a memory. Very durable, heat it to make it easier to stretch over the end of the light.
Guitar Guy
West Virginia
I'm pretty happy with how the paracord works and looks, but the tubing is a good idea to try sometime. Thanks for the tip, eh4.
eh4
You're welcome.
The tubing doesn't look as good as the para cord, but it is clear so it mostly doesn't look like anything; it doesn't stay wet, doesn't hold dirt, and doesn't dent from teeth- it rebounds.
Timothybil
The great state of Misery (Missouri)
It looks sharp, and there is no doubt that it works, but to my mind it makes the light a little thicker than it has to be. My solution was to get some heat shrink tubing, which comes in many colors as well as sizes, cut a piece to size, and shrink it over the light. Still makes a soft surface to bite into, and isn't as thick as the paracord. Another advantage is that it doesn't get dirty like paracord will.
eh4
I tried heat shrink tubing and it's great, but it breaks down, doesn't rebound... you'll end up cutting through it. Not a problem if you reapply it.
djjoonie
NY
nice wrap!
Here's what I did to surefire titan :)
lx70 :)
Fenix & LX :)
like samurai sword :cool:
