Suggestions needed - how to use multiple usb lights
iggs
I have a bag of about 50 of these USB lights
Any suggestions on a "project" they could be used in?
I've built a couple of lights in the past and can solder etc but I'm certainly no electronics engineer so need a bit of help with that too
Eg - I have been thinking about bias lighting for my tv. Could I wire a few of them up to my TV's USB port to get this kind of effect
Wiring them up in a group would be handy for some camping uses too. I have a solar panel I don't use much and a few freebie usb batteries I could use
Any help greatly appreciated
HarryN
Pleasanton (Bay Area), CA, USA
The first thing that pops into my head are lights that kids can throw into a swimming pool and dive for them.
I am assuming that there is a battery inside or is the power via the USB port?
iggs
Interesting idea [emoji362]
Power is via the USB port
HarryN
Staying with simple concepts, it seems like more or less the 3 LEDs are resistor regulated, so they just accept in a 4 ish volt input and turn on.
The USB port portion is really just a mechanical way to deliver the power - right?
If you found some coin cells that could feed the input, that could work for a little while.
If there is an easy way to pull out the circuit board, you could desolder the usb port and use the extra space for the battery compartment.
iggs
I think you are right about the power supply
Very basic electronics question:
If I connected up a load of these in parallel would they just draw 4V & how ever many amps they needed?
Thinking I could make a nice big work/desk light that was powered by a rechargeable usb power supply
DIWdiver
Connecticut, USA
Yes, they would draw whatever current they need. USB is supposed to be 5V, though, so they might be pretty dim at 4V.
