*** New Alpha Antiqued Brass Pen *** Limited First Run
Got Lumens?
Champlain Valley
Announcing a New Prototype Finish for the Alpha Brass Pen
This special edition is a standard brass pen that has been put through our proprietary antiquing process.
The process creates patina, but it also introduces pits, erosion, and other imperfections in the surface,
making every pen unique.
This variant features an Electroless Nickel clip screw.
This is a test batch, so I don't really know how the patina will wear. If you use the pen a lot, the wear areas
(high spots) will probably brighten up. Using a polishing cloth will remove the patina. We will continue to make
more if they are popular, but right now only 10 pcs are available.
