1 x 18650 1000Lumens
Rechargeable Tactical
Adjustable FOCUS Flashlight
>>>>>>Klarus FX10<<<<<<
------RELEASE-------
>>>>>>Klarus FX10<<<<<<
Dear Flashaholics and Klarus fans,
The Tactical Adjustable FOCUS Flashlight, Klarus FX10, compact & rechargeable, extreme floodlight and spotlight beam capability with next-gen patented optical lens, with extended range up to 300 meters, featuring the latest CREE XP-L HI V3 LED, using 1x18650 2600mAh battery(included) to ensure long runtime up to 260 hours, is released today.
Intuitive User Interface of the Tactical Adjustable Focus Flashlight Klarus FX10:
Main Features of the Tactical Adjustable Focus Flashlight Klarus FX10:
1. Adjustable Focus. Using patented next-gen optical lens for adjustable focus, you can twist the tactical adjustable focus flashlight FX10 to set any stage from spotlight to floodlight, even and soft flood light pattern will not dazzle users.
How to Adjust the Focus?
• ①Twist the flashlight head bezel clockwise to change from floodlight to spotlight
• ②Twist the flashlight head bezel counter-clockwise to change from spotlight to floodlight.
2. Patented Tactical Triple-Switch Design. Similar with Klarus popular tactical flashlight XT11S and XT11GT, FX10 is also designed with a side switch + tactical dual-switch, support tactical and outdoor settings to meet different user habits. The side switch has mode memory feature, and you can Lock-out both the side switch and the tactical tail dual-switch.
3. Micro-USB charging. FX10 is integrated with a digital intelligent charging module, supports real-time monitoring of charging status, prevents over charging, with a Micro-USB charging port to support 1A fast charging, work with 1x18650 battery with 2600mAh capacity to ensure the runtime up to 260hours.
Besides the biggest advantage Adjustable FOCUS, Klarus FX10 supports tactical and outdoor settings with 4 lighting levels and 2 flash modes, it is very compact with body diameter at 1inch(25.4mm), compatible with standard rail mount and very convenient when use Klarus TRS1 as optional remote switch. Based on these, the focusing flashlight FX10 is a multipurpose adjustable focus flashlight, that can be applied to Law Enforcement, Hunting, Cycling, Search and Rescue, Exploration, Hiking, Self-defense, Daily Use, etc.
