Sold/Expired [All sold: Acebeam L16 *Price Drop 6/3*]
moshow9
El Paso
Sale Terms:
  • US/US territory shipping only, unless we have previously dealt before
  • First Class shipping unless otherwise indicated
  • Paypal Purchase of Goods Option (no gift payments please)
  • I reserve the right to refuse sale at my discretion
  • Not looking for trades
6) Acebeam L16 XHP-35 HI Cool White [Sold to light ho] $85 $95
Emitter: XPH-35 HI (cool white). Amazing stock 18650 thrower. Tail switch goes straight to Turbo and is momentary or constant on. Side switch cycles through the modes (moonlight, low, medium, high). A double-click from either on or off on the side switch takes you directly to Turbo. Triple-click on side switch accesses strobe. From off a press and hold on the side switch will lock the side switch out (Turbo still accessible through tail switch), repeat to unlock. Includes box, holster, micro usb charging cable, spare o-rings, and a Acebeam ARC18650H-310A 3100mAh 20A battery.
1) Armytek Partner C1 XP-L Warm White [Sold on another forum] $35
2) Armytek Wizard Pro v3 XHP-50 Warm [Sold to Creekster] $70 $75 $80
3) JetBeam Jet-TH20 Cool White [Sold on another forum] $60 $65 $70 $75 $80
4) Olight H1 Nova Neutral White [Sold to Creekster] $42 $45 $50
5) Fenix HM50R Headlamp Cool White ​[Sold to Creekster] $45
Emitter: XP-L (neutral white leaning towards warm white). This is a forward clicky light that gives you the ability to use momentary on. Uses a TIR optic. Head tightened gives max output, while head loosened offers 4 modes from low to high. Has been carried and shows some signs of use with a couple of tiny dings and light coating wear. Uses either a CR123a, 16340, or 18350 battery. Includes box, instructions, original accessories, and an AW 18350.
Emitter: XHP-50 (neutral white leaning towards warm white). Very bright headlamp that has never worn on head but used a couple of times as a bedside light for it's low modes. Full Disclosure, the holder for the headlamp uses plastic that snaps in to place on the headlamp in set tracks. This allows for the headlamp to be held securely but freely rotate. There is very light wear marks on these tracks from natural rotation. See 2nd photo to see how light these marks appear. Uses either a 1x18650, 2xCR123a batteries, 2x18350 batteries, or 2x16340 batter's. Includes box, instructions, original accessories, both magnetic (but not magnetic charging capable, magnetic in that it sticks to magnetic surfaces) and flat non-magnetic tailcaps, and an 18650 battery (Sanyo NCR18650GA).
Emitter: XHP70.2 (cool white). Super bright! Has a momentary/constant on switch, with paddle switches along side main tail switch. Paddle switches adjust modes from Turbo, High, Med, and Low. A press and hold from either on or off will activate strobe. Includes box and all original accessories, along with Jetbeam battery.
Emitter: XM-L2 (neutral white). Tested but unused/uncarried. Uses CR123a battery or 16340 battery. Includes original packaging and original accessories minus the included CR123a battery. Swapped that out and am including a Keeppower protected 16340 battery.
Emitter: XM-L2 U2 (cool white). Nice rechargeable headlamp from Fenix. Press and hold to turn on, repeat to turn off. While on, a single click cycles through the modes. While off, a single click activates the battery checker (green is charged, blue is low). Battery can be charged while in the headlamp using a micro usb charger (included). Light will run off of a 16340 or CR123a battery. Includes rechargeable battery and original accessories.
moshow9
El Paso
Re: WTS: Armytek Partner WW and Wizard Pro v3 WW / JetBeam Jet-TH20 / Olight H1 Nova
Up for another look with some price drops!
moshow9
El Paso
Re: WTS: Armytek Wizard Pro v3 WW / JetBeam Jet-TH20 / Olight H1 Nova NW *Price Drop*
Bump-up. New price drops!
moshow9
El Paso
Re: Armytek Wizard Pro / Fenix HM50R / JetBeam Jet-TH20 / Klarus XT2CR / Olight H1 No
Added a Fenix H50R headlamp and a modded neutral white Klarus XT2CR to the listing.
Creekster
Pm sent
moshow9
El Paso
Re: JetBeam Jet-TH20 / Klarus XT2CR modded Neutral White
Armytek, Fenix, and Olight headlamps are sold to Creekster. Jetbeam and Klarus are still available.
moshow9
El Paso
Re: JetBeam Jet-TH20 / Acebeam L16
Moved Klarus light to modded section. Added Acebeam L16 light and price reduced on Jetbeam.
moshow9
El Paso
Re: Acebeam L16 *Price Drop 6/3*
Received, thank you light ho, this one is sold to you.
