Bocians custom 90+ CRI 4W GU10 LED spotlight bulb 3000/4000/5000/5700K
Bocian
POLAND
I would like to present my latest project. You will see that this time I went a little different way than usual. This project is a book example of reverse engineering of the product. I based it on an outstanding quality GU10 light source made by a well-known Polish Niviss company.
Below, you'll find the original, base product DS:
https://www.niviss.com/product/attachment/38783/nGU10.pdf
The radiator is made of numerically machined aluminum with a large margin of capacity in relation to the power with which the source works. Total active power taken from the 230V grid is 4W (after heating, the average power for basic color options is 3.8W). The temperature reached by the heat sink after heating at room temperature is ~ 50 * C. Onboard driver is equipped with the isolated and very fast output (frequency 60-70kHz) which means a complete lack of tiring eyes flickering LED source (strobo / flickering effect). The power system has high-quality components (including the Rubycon BXC series electrolytic capacitors)
I used 3030 Liteon Opto Series AQL and SL medium power LEDs (for special options) with high CRI min. 90. Liteon is a well-known producer of excellent quality LED emitters (one of my archived products based on AQL CRI emitters min. 90 on the spectro-photometric test achieved the result of 95 CRI). MCPCB made by MR Elektronik based on aluminum core laminate with a ceramic dielectric (3W/mK).
The two-structured diodes, The Liteon 3030, are connected in the 2s2p topology and supplied with a current of 140mA per emitter. An isolated driver gives the output ~ 11.5V voltage and current 280mA which gives the power ~ 3.2W with which the LEDs work. The measured efficiency of the inverter is ~ 80% with a power factor PF = 0.6 Optics – textured reflector. Wide angle of total emission approx. 120 *.
The following comparison of available color options:
Primary colors:
3000K 90+ CRI:
4000K 90+ CRI
5000K 90+ CRI
5700K 90+ CRI
Special-purpose LED sources:
2400K CRI 90+ bread pastries
3500K CRI 90+ fresh meat
4200K CRI 90+ vegetable
Housing in color SILVER + gray bezel, GU10 base (connected directly to the grid).
Input Voltage: 85 – 264 V AC
Frequency: 47 – 63Hz
Operating temperature: -20°C – +40°C
Lifetime: Up to 50,000 hours @ 25°C room temperature
Below all available color options:
3000K CRI min. 90 luminous flux 320lm
4000K CRI min. 90 luminous flux 325lm
5000K CRI min. 90 luminous flux 330lm
5700K CRI min. 90 luminous flux 328lm
2400K bread pastries CRI min. 90 luminous flux 262lm
3500K fresh meat CRI min. 90 luminous flux 282lm
4200K vegetable CRI min. 90 luminous flux 325lm
Each source has a 3-year warranty from the date of sale.
Total length of the 54mm source
Diameter at the widest point of 50mm
Weight 58g
The luminous flux of LED module for the 85*C LEDs junction temperature.
BryanMig
Bocians custom 90 CRI 4W GU10 LED spotlight bulb 3000/4000/5000/5700K
I would say go with the powermodule cause a t5 and led combo is the best.
