I posted another topic requesting recommendations for decent LED strips. But, from another topic on this forum, there is very little hope in finding a decent LED strip.
That's fine. I'm OK with exploring custom solutions. A few months ago, I went on a research binge about Luxeon's Class A LEDs and have always had an itch to do a custom setup. I'm really into making power supplies anyway, so custom lighting solution would probably make me as giddy as a kid at disney land.
What sort of low profile lighting solutions should I look into for flat-ish applications (door trim). I'd like to have good spread of light, so probably several LEDs recessed in a dado in the trim.
Aluminum Stock...Heatsinks?
I'm under the impression that heat sinks are going to be my main obstacle. For what it's worth, I have a 50x30"ish sheet of 1/4 aluminum on hand that I could cut into strips/pods and use for this project if that would help.
Desired Voltage
I'd like to stay at 12V if possible, as I have a handful of MeanWell 12V supplies of various types on hand. But, a different voltage wouldn't be a deal breaker.
(other option I may go with): I'm considering using a Forstner bit and recessing some IKEA (or other brand) puck lights. That may be easier than custom and work good enough.
Thoughts and pointers would be appreciated.
Desired Voltage
