Test/review of Shockli 26650 5250mAh (Green) 2018
HKJ
Copenhagen, Denmark
[size=+3]Shockli 26650 5250mAh (Green) 2018[/size]
Official specifications:
  • Type of Battery: Shockli 26650 5250mah IMR battery 20A
  • Size(mm): 26.3±0.2mm(Diameter) x 65.2±0.2 mm(Length)
  • Weight(g): 98±2g
  • Nominal Voltage: 3.7V
  • Nominal Capacity: 5250mah (0.2C Discharge)
  • Discharge Cut-off voltage: 2.75 V
  • Standard Charge: 0.3 A~2A (Recommend 0.5 A~1.5A) /4.2V±0.05V
  • Maximum charge current: 2A
  • Continuous Discharge Current: 20A
  • MAX Discharge Current: 30A
  • Initial Impedance: < 20 mohm
  • Cycle Life: 500times to 80%
  • Operating environment: Charging, 0°C ~ 45°C, Discharging, -10°C~60°C
High capacity and high current 26650 cells.
The discharge curves for the two cells tracks nicely and the cell can handle 15A without problems.
At 20A I stopped a bit early due to the temperature.
[size=+3]Conclusion[/size]
The batteries are good at high current and capacity, but at 20A and above it is best not to use continuous discharge.
[size=+3]Notes and links[/size]
The battery was supplied by shockli.com for review.
How is the test done and how to read the charts
How is a protected LiIon battery constructed
More about button top and flat top batteries
Compare to 18650 and other batteries
markr6
Engineer: Should we really have the word "shock" in our brand name? I mean, watch what happens if I...
Marketing Guy interrupts Engineer: Sure, why not?
