Product Details
IMALENT BG10 , "The Firefly" is a magnetic rechargeable bicycle light that can solve almost any problems for today's riders. Its OLED display clearly shows present output levels such as brightness, capacity, and runtime. Thanks to Imalent's premium reflector design, we've made it so that the BG10 has a far-wider beam than other models in this category.
The BG10 solves three key issues modern riders face:
-The light will adjust brightness to ensure that it never blinds anyone on the road (With great power comes great responsibility!)
-The cut-off line ensures that you and others stay safe at all times.
-Recharge on the go, a simple power bank will make sure that you never run out of juice!
Product Features
Features
Utilizes the latest CREE XHP50 LED, with a lifespan of up to 50000 hours and a maximum output of 2300 lumens.
·The multi-functional OLED display can show various parameters and settings.
·Built-in 2000mAh Li-ion rechargeable battery
·Size: 77mm (length)*37 mm (head diameter) *60 mm (body diameter)
·Net weight (battery excluded): 120g
·High efficiency constant current circuit will maintain constant brightness
·Anti-reverse battery protection
·Built-in thermal control module will automatically adjust the brightness to ensure comfort
·Ultra-clear tempered glass lens. Coated with toughed ultra-clear minerals and anti-reflective coating.
·Aluminium OP reflector
·Aerospace-grade aluminium alloy body, wear-resistant Type III hard-anodized surface treatment
·IPX-8 standard waterproof (2 metres submersible)
·1.5m impact resistant
Product Features
Features
