LED with uniform light as direct backlight
nikosb
I would like to know if there are any LEDs with approximate size of 1in x 1in that produce uniform light over the entire die area? I got some COB LEDs but I realized that only part of the die produces light. Here is an example of a COB LED
The purpose is to use the LED as the direct backlight for a HUD application.
nikosb
I think you want one of these woven fiber light diffusion backlight panels like the type that Lumitex makes.
Thank you very much, it looks interesting, I will read more about it. My feeling is that there is light loss as with any diffuser. Having a uniform Light Emitting Surface (LES) would eliminate any diffuser and subsequent light loss. Is there a limit on the size of the LES?
PhotonWrangler
In a handbasket
hey use them for monitor backlights so they can be made fairly large. I have a couple of small ones that I found at a local computer store.
