gearvita
- Joined
- May 17, 2018
- Messages
- 129
As the latest addition to the renowned SmartRing Tactical (SRT) Series, the Nitecore SRT9 is a powerful flashlight designed specifically for law enforcement, hunting, search and rescue applications. Get it with the coupon code "NTSRT9" on GearVita to enjoy the $15 discount and free shipping, only $102.79 you can bring it home.
Utilizing a CREE XHP50 LED that is capable of emitting twice the brightness compared to CREE XM-L2 LED, the SRT9 packs as high as 2150 lumens with beam distance of 246 meters. Apart from the powerful white output, the light is also equipped with four auxiliary LEDs, including red, green, blue and ultraviolet, making it extremely versatile.
The incorporated SmartRing Tactical technology enables the SRT9 to have an extremely intuitive user interface. By twisting the Smart Selector Ring adjacent to the troch head, users can rapidly switch between all 7 modes, and easily choose the desired brightness level. Tactical forward switch on the tailcap makes it more suitable for tactical scenarios. Powered by 2 18650 Li-ion batteries, the SRT9 has runtime as long as 250 hours, eliminating the need of extra backup batteries or frequent recharges.
The die-cast making process gives the SRT9 a larger heat dissipation surface. Together with the integrated advanced ATR module, the cooling performance of this light would be more than excellent. The process al give the light a unibody seamless body, ensures supreme structural integrity and has higher strength, lighter weight, smaller size and greater resistance to impact compared with flashlights that consist of three separate parts. Waterproof according to IPX8 whilst impact resistance rated as 1.5 meters. Whether you're using the white output for primary illumination or the color LEDs for hunting, inspecting, tracking and vision preservation, the Nitecore SRT9 flashlight is the high-performance flashlight you'll love.
Product Features:
● Designed for use in law enforcement, hunting and tactical applications.
● Die-cast unibody compact body.
● The world's first line of flashlights to feature third generation SSR (smart selector ring) technology.
● Smoothly and rapidly select brightness levels and function by rotating the smart selector ring.
● Utilizes a CREE XHP50 LED for a maximum output of up to 2150 lumens.
● A micro-textured reflector offers wide angle lighting.
● Boasts a peak beam intensity of 15100cd and a throw distance of up to 246 meters.
● High efficiency circuit board provides up to 250 hours runtime on the lowest output level.
● Equipped with unique multi-colored LEDs (red, green,blue and ultraviolet), red/blue signaling, strobe and location beacon lights.
● 7 rapidly switchable functions to select from.
● Versatile 500mW ultraviolet light at 365nm wavelength.
● Infinite brightness adjustment from 0 to 2150 lumens.
● Multi-functional power indicator light displays low battery status.
● Stainless steel titanium-plated clip.
● Stainless steel retaining ring protects core components from damage.
● Toughened ultra-clear mineral glass with anti-reflective coating.
● Constructed from aero grade aluminum alloy.
● Waterproof in accordance with IPX8 (two meters submersible).
● Impact resistant to 1.5 meters.
● Tail stand capability.
Product Features:
