$10 Discount and Free Shippping for Acebeam EC65 Flashlight
gearvita
Acebeam EC65 flashlight is a new take on an EDC sized flashlight the utilises 4x LEDs and a TIR optical lens to provide an outstandingly versatile beam pattern that is available in 2 different models to suit a variety of users. Adding to the versatility is the option to use 21700, 18650 or CR123A batteries. CREE - 4x XHP35 HI LEDs and a smooth TIR lens. Ranging from 20 to 4000 lumens with a 258 metre beam distance. NICHIA - 4x 90+ CRI LEDs with an orange peel TIR lens. Ranging from 20 to 2500 lumens with a 206 metre beam distance. The Side switch ensures quick and easy access to all available lighting modes and the USB-C charging system means you can charge up to 3x faster than older Micro USB models. A Li-ion 21700 battery rated at 5100mAh capacity is included to provide optimal runtimes.
$10 discount and free shipping coupon code of GearVita: ABEC65F
Coupon price: $114.99
Coupon time: July 18 - July 31
Product link: https://gearvita.com/acebeam-ec65-4000lm-rechargeable-flashlight.html
Option 1:
● 4 * XHP35 HI LEDs
● Smooth TIR lens
● Max Output 4000 lumens
● Powered by 1*21700 5100mAh rechargeable Li-ion battery (included)
Firefly: 20 lms, 4 days;
Low: 300 lms, 8.6 hours;
Mid: 650 lms, 3.7 hours;
High: 2000- 900 lms, 4 mins + 133 mins;
Turbo: 4000 - 900 lms, 1 min + 138 mins;
● Max beam throw: 258 meters
● Peak beam intensity 16600cd
Option 2:
● 4 * Nichia 90+ CRI LEDs
● Orange peel TIR lens
● Max Output 2500 lumens
Low: 250 lms, 7.8 hours;
Mid: 500 lms, 3.2 hours;
High: 1400 - 700 lms, 4 mins + 149 mins;
Turbo: 2500 - 700 lms, 1 min + 151 mins;
● Max beam throw: 206 meters
● Peak beam intensity 10600cd
Both options:
● Impact resistant: 1.2meters
● Waterproof: under water 5 meters
● Size:114.5mm (Length)*30mm (Head dia.)*27mm (Tube dia.)
● Weight: 82g (without battery)
● Carclo TIR Lens: product highly efficient optics with a hug variety of beam shapes
Product Features:
● Type-C USB rechargeable port for fast charging.
● Being capable of standing up securely on a flat surface to use in "candle mode".
● Digitally regulated output- maintains constant brightness.
● Side switch on the body.
● Over-heat protection to avoid high-temperature of the surface.
● Made of durable aircraft grade aluminium.
● Premium Type III hard-anodized anti-abrasive finish.
● Toughened ultra-clear glass lens with anti-reflective coating.
● Excellent knurling on the canister for firm grip.
lumen aeternum
Very interesting. But can you "lock out" the High and Turbo modes? Every time you "click through" those modes it will add up to a significant drain from the battery, for no purpose. Also these very high modes will affect your vision when flashing by in pitch dark.
Actually, those modes are pure marketing hype. 4 minutes or 1 minute is not useful for anything.
gearvita
It is unable to lock the High and Turbo modes. When it reaches a certain temperature, generally about 60 degrees, then it will automatically downshift.
gearvita
No, I said lock OUT. To prevent entry into those modes entirely.
The side switch ensures access to all available lighting modes, every click can switch to a higher mode. So if you don't want to enter High mode and Turbo mode, just don't click the switch more after entering the Mid mode. Hope this response can help you.
