Klarus XT12GT - Innovative Magnetic Charging Tactical Flashlight
gearvita
Klarus XT12GT flashlight, one of the the Klarus's XT series flashlights, has been developed with tactical use and self-defense in mind, is a precision-engineered illumination tool. Featuring 1600Lm impressive output and 603m exceptionally long-range throw, it is one of the most powerful tactical lights on the market today! Additionally, the XT12GT employs an innovative magnetic charging connector, which doubles as charging connector and keychain light. The patented dual tail switch design gives you full control over the light, allowing fast mode change - instant access to Turbo, Low, Strobe or SOS from any mode. This makes it an incredibly effective tactical torch for daily and emergency use.
$10 discount and free shipping coupon code of GearVita: KRXT12GT
Coupon price: $79.99
Coupon time: Aug 7 - Aug 16
Product link: https://gearvita.com/klarus-xt12gt-rechargeable-tactical-led-flashlight-1600-lumens.html
Product Features:
● Body crafted from aircraft-grade aluminium alloy with hard-anodised finish.
● Toughened ultra-clear mineral glass lens with anti-corrosion coating.
● Stainless steel strike bezel used to break glass, as a self defense tool.
● Dual tactical switch interface can be operated using just one hand.
▹ Primary switch: used to turn the light ON/OFF. While light is OFF, can be lightly pressed to temporarily access Turbo mode.
▹ Mode switch: While light is ON, used to cycle through outputs. While light is OFF, used to temporarily access either Low mode or Strobe mode.
● Features a pair of programmable settings for multi-purpose use.
▹ Tactical setting - access to Turbo, High, and Low modes, temporary access to Strobe mode.
▹ Outdoor setting - access to Turbo, High, Medium, Low, and S.O.S. modes, temporary access to Low mode.
● Can be recharged internally using the one-of-a-kind magnetic charging connector.
▹ Plug micro-USB cord into connector and attach connector to light's magnetic. charging surface to charge the light (only when equipped with a 18650 battery).
▹ Connector also functions as a 10 Lumen keylight.
● LED power indicator ring around charging surface displays battery's remaining charge.
● ITS temperature control and heat-dissipating fins help prevent overheating.
● Springs at bezel and tail help prevent damage from impacts, drops.
Related products:
https://gearvita.com/klarus-xt1a-tactical-led-flashlight-1000-lumens.html
https://gearvita.com/nitecore-srt9-smartring-tactical-led-flashlight-xhp50-2150lm.html
