Suggest a Durable Bug Hunting Light
D8Tee
==================Flashlight Recommendation Checklist================
xxx This will be mail-order or Online (location doesn't matter).
2) Budget: An easy question, but you may change your mind after answering the rest! :)
xxx Up to $50.
3) Format:
xxx I want a flashlight (hand held/self contained).
I had a Fenix MC 11 which I quite liked. Currently have a Rofis Mr 70 which I like as well. looking for a double A flashlight for nite time insect identification. ____________________________________________
4) Size:
xxx TINY - Every day carry (2-4 inches).
xxx SMALL - Every day carry (4-7 inches).
5) Emitter/Light source:
xxx LED (known for efficiency, longevity, and compactness)
6) Manufacturer:
xxx I want to buy a light from a large/traditional manufacturer that is ready to go out of the box.
xxx I would like a light from a specialty manufacturer (Possibly limited run/Custom).
xxx I am interested in assembling my own components. (for example a "host" or flashlight body from one manufacturer, and a "drop-in" emitter from another source).
xxx I intend to use "Primary"/Disposable Alkaline batteries based on the usual AAA/AA/C/D sized cells common to most stores.
xxx I intend to use Rechargeable cells (NiMH or NiCD) based on the usual AAA/AA/C/D sized cells common to most stores.
Really want a single AA light, but might consider some other power source. This is to be my insect finding, dark backalley light. I have a Rofis MR 70 as my powerbank, light up the path hiking light.
xxx I don't care, I can charge every nite.
xxx (150-300 lumens).
xxx Narrow Throw: I want a beam with a very tight "hot center" and minimal "side-spill". Good for distance viewing, fog, and looking through dense undergrowth.
xxx Less than 1 yard/meter (reading, other close work)
xxx 30-50 yards/meters (I have a big backyard)
Hoping to get a little single AA light with the highest candlepower, nice tight hotspot that will light up a spider or other bug in a natural light for taking pics. Throw is important, want that nice tight hotspot.
xxx Up to 30 minutes (I want the brightest [and potentially smallest] light for brief periods)
xxx 30-60 minutes (I have plenty of batteries just ready to be changed)
xxx Very Important (Camping, Backpacking, Car Glove-box).
xxx I don't know.
xxx Other, please specify __A fast operating switch preferable. _________________.
Maybe I want multiple light levels. (Some lights have 5-16 light levels.)
Maybe I want a programmable light.
Maybe I want a selector ring.
No I want a strobe mode. (Oscillating pattern to confuse/blind aka "Police Mode")
No I want SOS mode. (blinks in ...---... emergency pattern)
No I want a beacon mode. (Regular flashes at full power to show location.)
14)Material/Finish/Coating
xxx I don't care.
15) Water resistance
xxx IPX8 (Submersible to greater than 1 meter for 4 hours)
16) Storage condition:
Edc pocket carry
xxx Pocket/belt clip
xxx Holster
archimedes
CONUS, top left
Re: Suggest me a Durable Bug Hunting Light
Hello and welcome to CPF
As a new member here, your first posts will require moderator approval, and your post above has been approved.
Please do not start duplicate threads. That does not get your posts approved any faster, but only creates more work for the mods to clean up. Thank you.
Poppy
Northern New Jersey
You might want to take a look at
Eagletac D25A Clicky Nichia 219
the Nichia 219 is a high CRI LED that will render colors well.
You may also be interested in getting the D25A in titanium for a few dollars more.
D8Tee
Looks like a great light but it's over my price range by quite a bit, cheapest I can find it with shipping to Canada is 89 dollars.
D8Tee
Manker T01ooks great but I can't find a Canadian outlet to buy it from. Any other double A throwers with specs like this?
Max LumeOutput: 900LM
Peak beam intensity: 20,000 cd
(Drive by 14500 Lithium Battery).
xxo
Maglite ML25 2C running on Eneloops - not a AA light, but it will run on AA's using a simple homemade spacer tube made from a piece of PVC pipe or even some rolled up news paper. The ML25 has a brighter hot spot than any 2AA light that I am aware of with a nice big spill just bright enough to keep you from walking into branches and such.....it is about the same length as a 2 AA light but a little chubbier, which I find gives a better grip and makes turning on with one hand easier.
https://www.maglite.com/shop/magliter-ml25lttm-2-cell-c-led-flashlight.html
D8Tee
Maglite looks good, but it's too big. What about a light that has a UV Led as well as a white one. I hear that some bugs glow intensely under UV light.
ZMZ67
Colorado
Fenix recently released the LD02 V2.0 with a high CRI LED and a UV LED combined but at 70 lumens it is lower output than what you specified. The larger 2XAAA LD05 V2.0 has a slightly higher output of 100 lumens.
D8Tee
The Fenix LD 02 V2 looks like the best fit, thanks for your help.
D8Tee
NOW TO FIND IT ON Amazon Canada, which I cannot seem to do...
SleepyInTheSun
Denver
Did you have any luck? REI has reasonable coverage of the Fenix line south of the border, possibly MEC carries them north of the 49th...
ZMZ67
Colorado
I have the LD02 V2 now and while the neutral/warm output is great the UV output seems weak compared to other UV lights I have. The UV works fine and I believe it probably is 365nm but the output is only good for close up use.
tokaji
Hungary
I have the LD05 V2.0 for a few weeks. I find the UV output weak too. Yes, it is 365nm.
