Review: Fenix UC35V2.0: XPL-HI V3, 1000 lumens, 1x18650, beamshots, compare
kj75
The Netherlands
We often see that popular flashlights get an update after some time. This is often due to the fact that new and more powerful emitters have been launched. Like some manufacturers do, you replace the led, and that's it. But Fenix has done a lot research among their user before and the result is here now: the second version of the UC35. Same output but more throw than the previous version, new switch and charging option. I'd like to show you the UC35V2.0 and it's details in this review, we will have a look at the interface too. Above that, I will compare it some other flashlights in the same class and after that we go out for a lot of beamshots. So, let's start the story.. Enjoy reading and watching!
the second version of the Fenix UC35
N5isuRpkt504a6O0OCrWvwQfP_YJDiruMfHpQRv4qsKflIcehzRdzRxEZd9nPNVwGyfVnjyU75-NhR0iG-xUCD36kPMvnb1t53vR-4SU-IMH_JGIQeqLhOJBk-nbcfK3Buw8mU8F
improved and more power and throw
RZiy6AauaY3fB9VUUcBMTbHP6rhQEuMvzi-MYvBhviRO_PzNzIRIUB4K2O1BD5SNmpCEVz69xpw2989oU_DvuRhnnIPIMYslRr6NWTWdrub8AwQ2fKXpCGa4EwzJCmfK84YvYlQO
powered by a XP-L HI V3
uG4zD7HJaW6ZjUPiFW9RpRVjyrJgRGD-FJnWxsH7Iq6-ldN1gZg8Mju4nH9LaQOcuirA8AtQqFPiJ8TCSR6RjLJJAVS2-w06vuvzqHmhW215l4-jRTdo3e7Y6j1INCA5VA_JqYqE
pocket-sized tactical flashlight
1mZb2wWuPrpgb-_ynAYtMtPscJIquZkTHCzcY6RG9uVf7G_iaslbrwASwXDyhH1Y8s6f4m8MyGZIAwbaR1YAPlFwhMqMTn8wG6zx_wanU3R8tLCHw-_wy2DFIxz0xzyTB2loS26Q
a long-lasting 18650-cell is included
raliNl1yogqKIGaBYOp4etS0mWwpipSKF6N9siHQOAtEjv5J1flHqtjbgFB1CScl28rlQEvDMhBJ0yVYFGChikL0hu4enOPrMO_kQB3xOeacWUtwrGs3P_jZVGSbFHqLNJoA6h8A
First, a look at the specifications, given by Fenixlight:
  • Cree XP-L HI V3 LED, with lifespan of 50,000 hours
  • Powered by one 18650 rechargeable Li-ion battery or two 3V/CR123A Lithium batteries
  • 5V/2A Micro USB rechargeable, included 18650 rechargeable Li-ion battery
  • 140mm Length x 23.5mm Body diameter x 25.4mm Head diameter
  • 89 grams/3.13oz (excluding battery)
  • Boot-up battery level indication and low-voltage warning function
  • Digitally regulated output maintains constant brightness
  • Reverse polarity protection to protect from improper battery insertion
  • Anti-roll and anti-slip body design
  • Tactical tail switch features instant activation
  • Functional side switch for output selection
  • Made of durable high-strength and oxidation-resistance aluminum
  • Premium type HAIII hard-anodized anti-abrasive finish
  • Toughened ultra-clear glass lens with an anti-reflective coating
A chart of the output and runtime specs:
4WsOsFzvlmgISVt7JNEvTCBmt1Rk4UiDk2dNqu-8738rtouecWA_wCu2h3NpJMb8gRHbfFGTkVg1uEnrYsr4Kb7MlQhrA5_q-UcdIEpCW-ayI8Es0eG2Ldyi_x6oSxKGaW_jFb45
Unboxing:
The box of the UC35V2.0 is not surprise, it has the same style and looks of the actual Fenix-releases. A print and some main features on the front, application on the sides and the full features and charts on the back of the box. Beware that you don't tear the flaps; I mostly picked a tool to open the box because I don't like a torn out carton. Inside, a plastic container that keeps the UC35 in place, and most parts we need to use and charge the light. Because the battery and a charging cable is included in all Fenix UC-series, the only thing we miss here is a power source. So, a complete box; you don't need an external charger; the UC35 V2.0 is almost ready-to-use! I captured some shots of the box and what's in, please scroll down to watch!
another carton in "Fenix house-style"
3qrjbw4dHrfU-UszHOBiIBapbVvY5yqjrKQsbK1bfwL1piEjGgiwAi4EAwNwP4CQSg65ZRO0GqO1EfS_FgqVFy9LLhe91yJxe0fELnpYTUlr5OAjTooDHHIFjNJKoB4EbUv2soso
main features and a print on the front
G4y3NBujSWPPT4fd5e253rdKQS9VzXpnwerMqKVvfdrA167cU5tHSe3_44J0xcYNDnEiNxYmTL-Pc7uzza6kF88D3RwXsQBZJR5ybS8yteXmHEuPZev4feYGcjpslnN3JPOVRVqL
applications on the sides and full features on the back
gZDsjICegSUUvgEj_2TwnH1R4nPBEUhU-0UHRhwq7C6XYIwpVa0z6bcO2cfG4EA7r6Wejl2aw5I3Ou6QDHeTP4y5Y-9Yf65xrKSPJMEhmobTZ-X4APqnTQZjRHj12rNnkC_dhcfj
a plastic container keeps all parts in place
9uTE_HQJhMZFkTHXVdzADH32pFfmNDY70RD3Ky-FFXERdfWLneG55sUH2bcN1VOJNYmGR4hY5gr9KNdgbUiTKNX7JQ4Em5-e-nmu0t9s2pVsxqcYdZ6TyJwOherdST2OMpAukXxz
unboxed: except a power source all we need is there!
IaLO7kUd6ENdnruPrutvYMYcxnIFB-TMZZ1f-ihE_AeZl90dmo7D4NWi965WuE6EpauMK-_ENfN0D_IUl1afN4mls-l-TQOfPdqHu0O5PGmpx-JxWC_HE6rp0g7P7J0K-pVwv5pI
Impressions:
Everytime when I've unboxed a Fenix light, I notice that all products of this manufacturer are of excellent quality. Same to the UC35 V2.0, the light feels robust and well balanced. It comes in matte black, maybe other colors will follow later. The anodizing-job is done well, the grey engraving is clear; and I'm happy that you can't find too much information engraved on the body. As expected, the light can tailstand, but on the head it is stable enough. Thanks to the heads' design it has an excellent anti-rolling design, which I really appreciate. Tactical lights like these are good to handle with, same to this one: Thanks to the sleeves and the fine body-texture, the strong clip and the design of the head the UC35 V2.0 can't slip out of your hand. Looking into the lights' head we see a rather deep reflector that keeps a perfectly centered XP-L HI V3 emitter. A plus of this led is that it will the light more throw than the previous led, but the beam won't be to focussed. We'll see this later in this review when we have a look at the beamshots. On the head we see two striking details: Eye-catcher is the renewed switch: This is a metal-one with "copper-look" and has a power-indicator in the middle. This switch is insensitive to rust and more resistant when the light will be used in heavy conditions. Above that, I like the looks; it gives the UC35 a more luxurious look. Second detail is the micro-usb charging port: it has inner water-proofing treatment. This means that you never have to worry or the cover is closed securely. A very big plus to the new version! The long and very strong clip keeps the light in place, it can only be clipped on at one way to the body. Looking at the rear we see a double lanyard-hole and the big rubber main-switch. When we disassemble the UC35 V2.0 we see that the light is made of totally three parts. The threads run smooth, but could have some more grease. I advise here to do it by yourself. In the tailcap a strong spring protects the light against shocks. Also inside the head, the body and the cap all parts are well finished. Therefore, at the end of this paragraph about my impressions of the light, I can be short in my conclusion: The UC35 V2.0 is excellent constructed and finished. More impressions and details of the light below; please scroll down to watch a couple of pictures!
the Fenix UC35 V2.0 comes in matte black color
SGGB5C3nLV8SP_-AjrQu8ApFC9dGhOuLZQIUhNug9ZnGWgFvpkLTz0Z5r6IB6CIU7BMJxN-PsJ0-i4uFXKcSJpykw68YNH2bIQfvwymmCvuYepQeOvpyH791LUqo2WSIGW0zhQb-
can only stand on its head
E9aRgirALK2xE47NA2xIePYgfzX1d7C7kvu7EbAcStBaFfC-DRSkuqBrq00vJgb-b6ff88m7ENFraBrWCYH2N-pir71amQ-g_aJRI6T1O3EcllsMfM54r7-DBM-ECn2deZNWmwPm
a smooth and rather deep reflector
SG2ZUWXnl4yorGcegdFZGd9Pdn0GI0ibMeLG_4TozgGj10ryaOXb7HEVU-4oxphkTjftzaSrxsWkst_RdDCfg-_jJwXo6wQsl4rn5ZqVWpi0xjzS--yJOjTSeYvxCyPsqi58HLQz
a nice design that has a good anti-rolling function
wrh-ptEm4o3lm5ZYTIMINWJyPNntAq_Y-lDg329AyHz1LQR7amUQP-_dZtCfOcAOIPaMmmd-yUz1LnITN_yq4qHFKsXN22-QeD0d1BYmtvibJmhdIKat1UqZYookJYluP2h4FtsS
two battery-options: 18650 or two non-rechargeable CR123A-cells
8MLJSLh7kcI4HFfgA88dzHnnaHRooNp77vn2KJucEDTQZQMmJYtX61QHrUuokl1fUAjEycp2tC4uV4UmjynLYUR5qtsCMlFgMWvknwFMUXyYr6EPwyJ7_Uj6pGTJHrNShVzVl-y_
mid-sized flashlight
iMb9isQav7d-cyUFhAkuo3treupIPQxMbXqXPuQhXlmTPfKFexjzknP-j_Fee4NkB49awxTzC0AMY7zsijwq_gFX3ipYt4hULi_YODUZxeRaIvf7185YFFAPeIB_h-peIkP-nozQ
good grip thanks to the knurling and the design of the head
05NzK6JcPcxfZaM-u_vOP_gu7sL2o8ketAK3exOhl35w4NCE36DJkXCbP_3Kd4gQDjfJZ-YXzTN_rmRCderM485MDtASVYyp_96GJqTOsyGf879uCoQfv68p1uJj-FqeLT-zy9NK
the XP-L HI V3 led gives the light a nice combination of output and throw
xguF_zTg7lL17-Hdm9iIQ3bz6mxvxWeivLlCUx-zDpEf_cJVwYzYXnmRtYHnVkUUjFWPDegvp5ekyvtvqF3MdM3GZueKeLKKOAuvdqFezZh4mPZNUU3KdZLPvdSzmsUn1eSBT486
the new metal switch: long lasting and anti-corrosion
unpPwQp-h5pVfYhUfwZLF_H6948EA3hIT2dGFWAgdhXJhg8tMsiy_w_pAKoxQjvLfYq8qWsbSsaZsLouPnGSD--fcJcWHW_6t7Yaq7wljnAVOtStN4R_FCLPQGMW51Cegj_NWq8s
an important spec on the UC35 V2.0: it has moonlight-mode
W4vVEStN6l0ZgHrZO4C1cqhbv8hhata-PENYVP0ipGOW2vHxakGkGUL_YrKAr3rHrOUcoi6V1lyz7l7s8zaJVhRiOH3cuy_s1RAf3wC2w6RG9qn1S7kfs5uVGUBTchgg8iN1jLGm
the emitter is perfectly centered
7Di7irySuX2GIimXFIydMe6ZkCDApGrx99k3_6-dK-eqKHGmm4aeAyQ8fYe8eDrA9G2Uk95oDj3R3FSH89cKGy1ADGfz3J2bN14dXdFDmQWyzlICrvh4qgzQo7t8BK5QaR9OMOyP
specialty on the charging port: it has inner waterproofing treatment
JVmpzydUmx6cE9CTaVNo-tgl6SkIKAPYalv2Y3FrbddO--7Enz7lR4iWH-9VgBrEdXuooYSOJZmbO6M37YzPZgSRgd8zP1CrbredgL1fZXfnfipuYEdEXhiHMMjE6tCpNLBKeKqY
a look into the unscrewed head
9mPQ_MK_dGZsSNUIsdlu3KX0CuyIFVWKMnvCqxV_9EUfd9Il0ikAy23NoRP0BKfpCKkRd2ZHQ3lrvLauc7ttpwNtZQEaSlS1KUfKEoPVAtXogHXc8kNs48EbuHLGmjAn3m2c2OAO
a strong spring in the cap protects against shocks
8kcQudImHdaxSvSRo8lk4XOEd3iHi5a4ZodvOo8oMPbdZT3ZDcL0oMuDsrC6yNgdkf0zHQn7jtyzfCmkVo3CCTJ2hVKj4IeisxLXtpF8tkJeVWJA612CmzjCvBP7sfCGcPT7g7ox
there's a power indicator built-in the metal switch
ddrAlIN_CR8k54svxrmTJa71iOzpABCOHmKuPeZrPBt9i2Rq_P0jIEj7-XLDf2yiApXnDkeSRZnCrhtnxpLqGOXAlB5hNWoCt-34jmj6bLp0MHefxNT0bnlbf0qjIJpatsz5buBd
the cover protects against dust
-DI2vg8XlKLG6OGFNKgffpNXXxow5aX54lqpxpw-QAO1wPYdvsrQGVx0PVlKCiMDK2-loZOdSytp-Lt2x-gaxi_ZZxqwOXU2e6kTBOuFZqyGhMXLYJPbunZiaxXcj-IHtrefu06G
engraving is done well
FCvNsqIG_YjOkUEBEGPJuWsz83_niQPl5YFt9X6eiVXxjVLUInByFmhOjR6rEmBEgUU8hx71HoCp05sowZN_HGJMaVEf1gIuwsq__s0AJYHG5x7tSWgfgnpAP1W19_-3JTHhDzFv
two holes on the rear for the lanyard
48KH5aE3Gt8oFI5WH_cr2fXzjEzPM-7rhY0zF-M_CJgtb9sa1BajBE00GQUORwycaj94_gxCmvcN_w6pe7BywHRSKytapYg_lCiBOX5FQnsUA0NNbqzqA8ftuE0LI3KSqZtMXONv
the UC35 V2.0 in the holster
LKWceuYVL3A4ONn1TeOOeRdqrogPGKv4PgYyiRy3k4wIrST0gcYGsaZitx5HLae83KrmQyLB1E7vPb2AUNWfdzca-VjfvZPkOYFiODdgadng5rO8HmzMADPdVRvsanvMK5bvKNya
a good option for night reading or camping with the optional diffusor
v9hJRj7wsYah6mQ2_e2yAA0lk5d4o9IXc6FG9Q2gVQ2TVMgNaZa_dX8hvCLf6Dsm7fxQR1-l_Bgqe22G81fEbOEdx9HiC7K75PvB2q5Z4WGC0g9kavqTzh4is4TXYA4xR1_AE7Sv
or use it a bike-light with the Fenix bike-clamp
8ks9qn7qAoLTdY5hf1Gs4Lu2ohZ0fwoGOsCBwTVu7Cl2QG75xv2z143KvTexAk8yqXXoDxRYI0pzL1YWd86LFiUV6qoCifBVdwQx9WGJ0R5WxnxsZMEmLVdvtxVSv7s2sgZLlbAJ
together with a Ruike-knife, that is produced by the same manufacturer
CZIE4IxNE0BEvITb7uqdTcPSqCAjLjG93nIiH7gVIQ79NaoL3n9QBt1PZdAA2Ao_I0LBIpkyKTuL0RBEbXy3TqI6F69L80RysfVW7xsr9sTx18QxSoB2H0zuPrMHm5cmzfMqwTTr
the big TK72R just has helped it little brother by charging it..
3Qh7NhpkdAn7WLs7T0yInszAGCL4L2JWp6wkaQ23-Cqo16rHQF7L4rtk2Hyu72hBhbThgQw8yTK4krOA6REJuG0kqX_GMGQJI6JmlEVJXoG8S5zbTlkDHHhz52bWlZx0XoNTFPz9
User interface:
It's good to see that rechargeable flashlights actually almost have the same size as the previous generation of non-rechargeables. The UC35 V2.0 is compact enough to wear it in your pocket, or to clip it on to your clothes. The light is well-balanced and easily to control by one hand. The big main switch and the side button can be controlled accurately, even when you're wearing (tactical) gloves.
Before first use, the light needs to be recharged. Relative to the first version, Fenix has renewed the way of charging. And I'm sure that all user will be happy with this. I works directly now, simply plug in the jack and the charging job starts. You don't have to press the tail-switch anymore. Good point, this can't get wrong. Only thing that you have to keep in mind here is that you don't forget to tighten the head and the cap: the light indicator doesn't show when there an error during the charging progress. Charging an empty cell takes between 3 and 4 hours; the indicator lights up in green when the charging-job is done. During the charging, you can use the flashlight on low-mode. So, for example: In combination with a powerbank you can still use the light in case of emergency.
Like we're used of Fenix, the manufacturer has kept the interface simple and easy to work with. Sometimes, I give a flashlight to a "non-flashaholic" to try it out. At this way, I can check or the interface of a light works for everyone. Result of the test with the UC35 V2.0: works for everyone! The rear button is for the power, the metal side-button is to control the modes. Half press the tail switch for momentary, full click for constant-on. The light starts in last used mode, except strobe. The half press is a good option for those who want "silent-operation". To change the current output mode you need a second hand, the side button has a clear pressure-point and is easily to find because it lights up for about three seconds after you turned on the light. By tapping the side button you can cycle through the five output-modes; if you press and hold it for about two seconds the light turn into strobe. You can start directly at strobe by holding down the side button and half of full press the clicky at same time. Modes can be changed with half-pressed button too. A simple and effective interface, but I can understand that some users would demand a direct mode like instant-turbo. An interesting addition to this light is the moonlight-mode. It seems that Fenix has listened to their users; a lot of people like a good low on a flashlight. There's less risk to disturb your sleeping housemates and, above that, the runtime has become much better: More than five times! I showed you earlier that the UC35 V2.0 has a power indicator in the button: Steady green means good to full, flashing green means sufficient, steady red for poor and flashing red means close to depletion. The indicator only works when a 18650 is loaded, the light can run on two CR123A's too. The UC35 V2.0 can be locked out by releasing the cap or head a bit.
The UC35 V2.0 has a no-nonse interface that works for most users. The presence of moonlight is a big plus. Personally, I'd like to see some instant-modes, like moonlight and turbo.
Modes:
The UC35 V2.0 has in total five output modes, in order of: MOONLIGHT > LOW > MED > HIGH > TURBO. Because Fenix has replaced it's eco mode (mostly 5-10 lumens) for MOONLIGHT, the step between the two lowest levels has become a rather big one. Maybe a sixt level would be a good solution here. No instant modes here. There's one special mode on the UC35 V2.0: STROBE. No SOS on this tactical torch. Information about actual VOLTAGE is built in the side switch. The light has a LOCK-OUT function too. So, nothing special on this light, only the main modes we need and one for self-defense.
Size comparison:
For the comparison, I picked some lights in the same lumen-class. The led of the Thorfire TK15 is different, the Klarus XT11S is the larger one of the three and uses the same led as the UC35 V2.0. So, an interesting couple for my beamshots! Later in this review, I will show you the results!
18650 battery, Thorfire TK15S, Fenix UC35 V2.0 and Klarus XT11S
QElCKMYYweGu0pj3gcZhbDOwgpqqHMe5pJiFtAuTAhAvq-avfLpKTg9xSh1HE6FusnYsDsz3RxmPtZL_c-8saCT_9t4G807xQGPVOpjOCaiMjQUVUTrMd7IQ2qMZOHcP3HNeIF_S
WewuA4skTPz339s1GdufHD0fsunyT9x8JZxH-zIImLhTUdp5GNzOGB3fA4uMuUkh5VOBN_27sHCxaFctwhsFervZlQPywVmT0KZ647hOtjxIqvBYhRKdCeH_TZIfQjyqO59-e2Hn
eIcSs6NErcA9B8-BbSwsaGAlLwj8VmBx11JfHN12yrR1jrjfdJuGwvb9DuoEXyprC6w9iqoztENdYnsnlggRUu_vOfc8_NhWYbwwX-Z_ZIIFVIXGaxZodoWevrdTciSd5xX_OFar
the heads: XP-L2 at the left and two XP-L HI V3 leds
1Z0kf1c32skvZvN8F-9D9iwzBMWctlQ6rcMOunA6E1mN6e0j6tztMakWI-tNleA5ZUabTTONYuSjn3hFn18SONxn07ez1r-6mzLT_nLGuP7kcWdKJgqikKpemuPcckViANm9Gy2m
the backs: Thorfire TK15S, Fenix UC35 V2.0 and Klarus XT11S
4z_BUttzgr7KlhHXr3c9s0WaSvPaGNFGwP_5230yAqVvwyKs7zQgyrjFQTfSrUHOt6PSh9osO0IoYYpy5_mtfYvO-tmR9wxDtRiC_eho7OwLVbeJnVnOGCIVrCIlZ-kbZny-sGKR
Tint:
When I did a quick check about the (coolwhite) tint I mentioned that it was pretty good. The photo below shows this: Compared to the others the Klarus shows more blue in the spill and the Thorfire has a yellowish blush. So to me, the tint is ok on the UC35 V2.0.
jjGpR-uobCxX6uaMqmT5ku96Sf_YYpnDoeNmZCm0HwuHXTKha_sT4rC1Lcax8AzmxgW4ll8Y2ljkpeeYnijyBcpzsf3JHd-jHw84sMCA6PAao6TAmVGKiwxmjcSR-aCiyLi3_gGe
Beamprofile:
The XP-L HI V3 is a led that gives good throw, but the beam is no to narrow. On the UC35 V2.0 in combination with the smooth reflector, you get a flashlight that reaches a good distance to its size. So, a good option in and around home on the lower modes, and one the higher modes a good solution for tactical use. We see a rather small hotspot, a medium corona and big spill. Later, when we go outside, I will show how this looks in real life. I couldn't detect PWM at any mode, which is a good point. I can tell you also that the beam is "clean" and free of defects.
Highest time now to see how this compact Fenix performs! Let's have a look at a couple of beamshots that I took. First, I will show the five output modes with the beam projected on a white wall, followed by a GIF-animation. Distance to the wall is about one meter.
Camera settings: ISO100, WB daylight, F/2.7, 1/125 sec, 35mm
C9k5w7njiaKY8B0axEEjcdg9iPrQ6245aWfZhu-PaMjbmw7jgB1mlv7AWUlUL3Ox5vFShfk9-REfWl4zpmBEtv5TGgJPtmkJtH9MMlhtNFHhtbMQ8ckCXfeoxINVY-t4q7d86fgq
b-vWYzbzqYZbgFyIlnHd1QLCErb1uVc_o2vi7Xmbyr6m14ZCoqQLn-yOH6rtmHxEOkclfyYozdxByoXd_9Wi_BF6c2rf14K8-j56IoGtaykrucXDZomAgwXS7g0TESY8muPgF0rg
pS8OuosIR_5CB167WXuAYVRyyD1IBaOzyPpy1kyOhE7ek2a5ivQawAoZxy1uTf8lfL-k2V4Jw7XCtWcL767MGBVgb7gznF9XIkMXYTzBj2AUUxUVnjqtDzGqjBKB2acs0ijxckzD
aIdcyLD3OC-UVKmYw2BElHwq4HKj5d7unJhEGCjvNmgiKK72d5KczhJmQs55iRQYeLBcx6obmVyefgquQ2jOya5NAd5tUhQOu8SR6pdjPCA4B4G0L_pPO1OJCUpJxQD5qub9n0y-
qQapdZb4lhVGY85KTD3nAFwNAtLilXrDZIL614qKLFij0_qNOM6twdCJgkeTyrqjlapkrM3YWbhreash0aIhkc2AacQuYeBnAHxYBtXBg2OUkT-bQ6RTd7SRBb4y6YESykVF-YLO
GIF:
Now, a look at the main thing that a flashlight is made for: Bringing light in the dark. The location is a dark forest here, I'll show you the five levels of the light followed by a GIF.
Camera settings: ISO100, WB daylight, F/2.7, 4 sec, 35mm
444g8Ly3ZPV7aKQHzzStK23VCXYlc_t_v_zXCUlACJhxNaS4QO-_EnlvTpBD-X_QlJm8DwNJ8Xrr6LzQ93JpFUcRq8kp_hr_AIFsWH4R-rnIzKf7Hqhx1RczbdKGGAcbd_tHNXt_
96vXnVf-V9zmNa7qOKGlP952frmEcz-bpoWR27smsrMrRtF-b5CvrHdCMszFtX-UbV8aaMy0ifHOesLntmlcxO8doiicG3ZccjLKT5JDY-UGUSyTGizneeuv5DIM_tEeJp7aOd9F
-FoB-pfHvptwaRmh24ocC8pz_cM5QcowTMKENdq0Rrin0JBzTzV1XolSKeglRFtR2rHKYqWwxvF9_WYQwfml7V-AMtj_SRSKq7AYwxWLc6LDo5wx8d8XQJ58JKhGWAMzfK9ONbkj
7RBnOATdKtg2hHNpcz3WI91HVghW91fxNFU36SN9h7eG9nzHJR_zQk_mjm1wulU6jouD1PoxPbId7a87i8NS_R1ZR1knKV52vZmk9TxdcyMZzE0JXJtTZAY_s5_NOWNN2VeBlBem
87PTW0FozWMVxDjkbqLn6OoWgYcpos3J8O6BqXal7QTSIkZX2c-8tD8y5EskFPuulXrs1lSH7QAuS9-Zp1EWAdV1QskPKO1qMnxyoBfk9V481L1xIAaaYVlLQ8yQWUgm-3evEsAW
GIF:
Now some pictures with the light in hand, that show that the UC35 V2.0 is suited for a lot of applications. The light is on Turbo here.
the UC35 V2.0 on maximum output
GbJ17bv6hkPVFoq9CG0sTKqGWgDyrt0wWPcQwYV8iCsFrWb_8d6W4pwcnDdMvReNyM88F8xJCMNwac5Aoqw6e3aBOodxd6ui2kpcEWVbOdFCJQZx-NDQ_VnX9fPFjJCoLIQEw2xm
hppbfhDrvOVsaj7q9hBWrgAncGFvuzlYaJpADE6t_jZg8Hf0tr9wMaUjZHIUuW4OymVyJ8EjT-dGFRjFWAQxX7Jt5kt_6YLjQZxSWJQf_B01GL4Cqlvm4pUUWNMtmfa5JDlBIYQx
Let's see now how the UC35 V2.0 performs against the others that I showed you in the comparison-chapter. The Klarus XT11S has a deeper reflector and therefore some more throw, the UC35 V2.0 clearly more spot and a wider beamprofile.
the UC35 V2.0 versus the Klarus XT11S, both on maximum output
Beyond that the Thorfire TK15S has a warm tint, you can see that this light misses good throw. The beam shows a "hole" at medium distance.
the UC35 V2.0 versus the Thorfire TK15S, both on maximum output
Another picture here on a field that shows that the nice combination of flood and throw that comes out of the UC35 V2.0.
Z5PdPLMX5-ciYVuxcy75WdUYFhomahrs1zigV2NcYfgr7Jrgvl2aoSSqqPJ5inqT_se8mkz7MjztyY-I3fkJbWxWVHHjWMSmDqNW9zmVVJMLytX0ZyiiZ8UxK14P2qXA-EpCyp7Q
Conclusion:
Fenix did a very good job by updating the UC35. Especially the simplified charging option and the addition of moonlight mode are big steps up. The inner water-proofing treatment is also a big plus, certainly for me because I live in a region where it often rains. My thoughts about the light: It feels like a Fenix! Durable and stable with a no-nonsense interface. But, personally I would like to see some instant-modes added. The beam is a good mix which makes the UC35 V2.0 a pocket sized all-rounder. An extra mode between moonlight and low would make it even better. But, my overall conclusion on this flashlight: Recommended!
Special thanks to Fenixlight and Knivesandtools for the opportunity to test the UC35 V2.0!
