- Joined
- Mar 7, 2007
- Messages
- 644
This sort of charger for them?
https://www.ebay.com.au/itm/CR2032-...601853?hash=item1a4bc8d1fd:g:SvkAAOSwGXpa0yOX
They are only really useful when used at an extremely shallow depth of discharge. And for that they need to be in a device with built in charging so it is easy to be frequently topped off.
If you run them dead and then recharge them they wear out very fast. It is actually cheaper to use disposables in that scenario.
In a general sense I don't see a use for that style of charger. What is your application?
Are you sure that the 2 batteries aren't in series giving you ~6v to the LEDs? This is quite common practice in LED lights and if so it could be brighter than a 4V lithium ion type battery initially. If there are 2 in series they will sag in voltage under load to less than 6v while 2 rechargeables at 4v would not sag nearly as much giving you probably more then 2v more to the LEDs (8v vs 6v).Thanks parametrak. I use them (two) in a loupe with LEDs and the loupe is mainly used/designed to inspect the sensor of a DSLR for cleaning.
The loupe can and is also used for other magnifying purposes but runs CR2032s down quickly - hence LIR2032 which of course also work at ~4.0V rather than ~3.0V and means the LEDs shine brighter which is somewhat better for this kind of use.
They are only really useful when used at an extremely shallow depth of discharge. And for that they need to be in a device with built in charging so it is easy to be frequently topped off. If you run them dead and then recharge them they wear out very fast. [...]
