gearvita
- Joined
- May 17, 2018
- Messages
- 129
Wuben E503 flashlight is a mini portable keychain flashlight, with pocket clip provided, easy to carry everywhere. It an be used as an emergency light, powered by 1*10440 battery, with 150 lumens brightness, max 60m brightness distance brings further bright distance. It is switched on by simply revolving the head, with one mode design, easy to operate. With the waterproof design, you don't need to worry about rainy days, it is a great tool for people who needs to go out in the night.
Main Parameters:
LED: CREE XP-G2 R5
Lifespan: 100,000 hours
Max Output: 150 lumens
Max Beam Distance: 60m
Battery: 1 x 3.7V 350mAh 10440 lithium-ion battery
Mode: Low - High
Waterproof: IPX-8 ( 2m submersible )
Impact resistance: 1.5m
Product Features:
● Wuben E503 adopts 6061-T6 high quality aerospace aluminum material, solid and durable for use.
● Mil-Spec hard-anodized for extreme durability.
● Adopts latest CREE XP-G2 LED as light source to bring super high brightness, up to 100,000 hours lifespan.
● Up to 150 lumens output and up to 60m beam distance, you can see clearly in the dark night.
● Powered by one 3.7V 350mA 10440 lithium-ion battery.
● Battery is rechargeable circuit design.
● Micro USB general charging connector with charging indicator function.
● ATR technology can regulate the temperature to prevent overheating from your flashlight.
● IPX-8 waterproof level, no worry about the rainy days, 1.5m impact resistance to suit for harsh environment.
● Toughened ultra-clear mineral glass lens with anti-reflective coating bring up to 99% light transmittance.
● Two setting modes, low light and high light to meet your needs. Just twisting the head switch to change the mode, easy to operate.
● Tighten the head to turn on the light, fully tighten to max output, loose the head to turn off.
● Chic and compact, only 25g, easy to carry, you can put it into your pocket or bag.
Product link: https://gearvita.com/wuben-e503-led-flashlight-150-lumens.html
It does not matter when and where you need a flashlight. At the party, you can create an open flashlight atmosphere. At night, you can turn on the flashlight to light up. During the day, you can be used for decoration is very beautiful. Such a practical and cheap flashlight, don't you hurry to buy it on GearVita?
Related products:
https://gearvita.com/wuben-e01-mini-portable-led-flashlight-100-lumens.html
https://gearvita.com/fenix-ld02-mini-led-flashlight-100-lumens.html
Main Parameters:
LED: CREE XP-G2 R5
Mode: Low - High
Product Features:
Related products:
