I was just about to order some Eneloop pro AA, And then I found out here that Ikea Ladd batteries are probably the same as the pro's.
Good news, they are a lot cheaper!
but, doing some more reading on this forum I noticed some posts mentioning that the pro's do not last very long at all, I haven't really found much more about this issue, if this really is true then I guess no more pro's for me.
So here's my question: I am using my Fenix HL50 daily So I go through quite a lot off batteries, so far I have been using Eneloop pro's in this light, I have quite a few of these so I don't know how many times they have been charged.
I did some measurements this morning;Letting it run on high ( 150 lumens), and now and then checking if the turbo ( 285 lumens) worked.
after two hours turbo stopped working, I then took out the battery and measured the voltage; 0.97 v.
5 min later only low and mid setting where working,i measured 0.91 v.
this is normally the stage I notice the battery is empty and I replace it.
Should I go back to regular Eneloops for this light?
I also have a Nitecore EA81and a ThruNite TN4A
these are being used strictly for emergencies, so the Pro's hardly get recharged at all, so I would be okay here.
