Winter is coming and in order to avoid seasonal boredom I want to try to keep doing my outdoor hobbies with a good headlamp. I also want this to double as a camping/backpacking/hiking headlamp.
TLDR:
Online or in-person, doesn't matter. Located in NorCal.
2) Budget: An easy question, but you may change your mind after answering the rest!
Up to $100.
3) Format:
I prefer a self-contained headlamp but am willing to consider ones with external power sources.
4) Size:
Not sure how to described headlamp sizes, but it's going to be worn for long periods of time so I need it to not be too heavy.
5) Emitter/Light source:
LED (known for efficiency, longevity, and compactness)
6) Manufacturer:
I want to buy a light from a large/traditional manufacturer that is ready to go out of the box.
Short answer: NiMH in AA format
Long answer: I want something rechargeable as I'm going to be using this regularly, but I also want it to be able to take AA/AAA/C batteries so I can carry backups for backpacking and hiking. I know NiMH, being AA format, is the obvious answer here, but I'm also willing to consider other power sources with AA/AAA/C converters/adapters.
It'd be cool to be able to recharge directly from the headlamp, but I don't care that much.
I want to illuminate my entire backyard or a campsite (150-300 lumens).
I want to illuminate an entire field, the neighbor's front yard several houses down, impress my friends and neighbors, etc. (300-700 lumens).
All Flood: I am doing "arms length" tasks like reading and campsite cooking.
Wide Flood: I want a defined flood area for semi-close tasks like after-dark campsite tasks or working on a car.
It'd be nice to have something that can also adjust to Narrow Flood or Wide Throw, but this needs to have a Wide Flood/All Flood. I'm an archer and need a beam wide enough to be able to ensure the range is safe before each shot.
30-50 yards/meters (I have a big backyard)
50-150 yards/meters (I live in a very rural area/farm with wide open spaces)
90-120 minutes (Runtime is moderately important, but still not critical)
3 hours + (I critically need this light to run on max for extended periods in between battery changes/charges).
Very Important (Camping, Backpacking, Car Glove-box).
I don't care.
I don't know.
I want multiple light levels.
14)Material/Finish/Coating
I don't know.
15) Water resistance
IPX7 (Waterproof to 1 meter/30min)
IPX8 (Submersible to greater than 1 meter for 4 hours)
16) Storage conditions
In house (temperature/climate controlled environment)
TLDR:
- Will be on head for extended periods of time so I prefer for it to not be too heavy
- Needs a rechargeable power source, flexible on the type, but it also needs to be able to take easy-to-carry and obtain backup power sources (e.g. AA, AAA, C-cell)
- Needs to be able to illuminate up to 50 yards to a level where I can easily identify anything within those 50 yards, and have a wide and bright enough throw that I can easily identify anything at least 15 yards to the left and right
- Strongly prefer a battery life of over an hour while meeting those illumination requirements, but am willing to live with having to change out the battery
- $100 budget, but am willing to flex if it meets more of my preferences (more preferences in the details below)
Up to $100.
3) Format:
4) Size:
6) Manufacturer:
I don't care.
I don't know.
I don't know.
