gearvita
- Joined
- May 17, 2018
- Messages
- 129
Klarus Mi1C is a unique great mini-mighty bright EDC flashlight for everyday carry. Mini size at only 54.5mm in length, and using XP-L HI V3 LED and one high performance Klarus 16340 battery with micro-USB charging port, this rechargeable tiny light delivers 600lumens, with maximum runtime up to 9 days at moonlight mode. The Mi1C has tail-stand capability and a magnetic tail cap that can be affixed to a metal surface allowing hands-free illumination! This comes in handy whenever you're looking for something you have lost or whenever you're working on something in the dark, it is a very useful tool especially if your car has had a break down and needs to be fixed at night. For other flashlights, if you prefer to keep your light on the low brightness level, you need turn it off in that level then turn the flashlight back on, and then turn on to that low brightness level. However, for Klarus Mi1C flashlight, one-touch access to the low mode, yes, you can! Easy and conveniently! A lock function is designed to the side switch, lock out the switch to avoid accidental activation in storage and prevent accidental damage to eyes from unexpected activation by children.
Main Parameters:
Emitters: CREE XP-L HI V3 LED
LED Lifespan: 50000 hours
Luminous Flux: 600 lumens
Beam Distance: 40m
Battery: 1 x 16340 or 1 x CR123A
Working Voltage: 2V - 4.2V
Output: 4 lighting levels + 2 flashing modes
Reflector: Convex lens
Waterproof: IPX8 (underwater 2 meters)
Brightness Levels and Runtime:
● With a 16340 Battery
High (600 lumens) - 1 hour and 12 minutes runtime
Medium (45 lumens) - 5 hours and 37 minutes runtime
Low (10 lumens) - 32 hours runtime
Moonlight (1 lumen) - 6 days runtime
Strobe (600 lumens) - 2 hours and 24 minutes runtime
SOS (45 lumens) - 15 hours and 45 minutes runtime
● With a CR123 Battery
High (305 lumens) - 2 hours and 21 minutes runtime
Medium (45 lumens) - 11 hours and 48 minutes runtime
Low (10 lumens) - 55 hours runtime
Moonlight (1 lumen) - 9 days runtime
Strobe (600 lumens) - 4 hours and 42 minutes runtime
SOS (45 lumens) - 33 hours runtime
Product Features:
● Mini-might brightness, thumb-sized.
● CREE XP-L HI V3 LED, maximum output up to 600 lumens.
● Extreme long running time, up to 9 days in moon mode.
● Professional optical lens design, even-lit flood and soft beam.
● Magnetic tail can affix the flashlight to any metal surface, free your hands when you are working.
● Fade-in and fade-out function when the Turbo mode is the initial mode for on and off to promote eye safety and improve the user experience.
● Newest intelligent temperature protection system(ITS) monitors internal temperature and adjusts output to regulate heat dissipation, protects LED and internal components for a perfect balance of output and safety.
● Intelligent battery capacity indicator to view remaining battery capacity at any time.
● Unique lock-out mode prevents accidental activation, avoiding battery drains during storage or traveling and prevents unintended directly shining into eyes.
● Reverse-polarity protection prevents damage due to incorrect battery orientation.
● One-touch low and with mode memory function.
● Aerospace aluminum alloy construction, CNC precision machining, Mil-Spec HAIII anodizing, anti-abrasive, lighter and robust.
● Compatible with CR123A and 16340 Li-ion battery, Klarus high performance 16340 battery with a Micro- USB port is included ( installed at flashlight ), no need to bring a charger, easy to use, safe and reliable.
Compact, lightweight, easy to use, and insanely bright - the Klarus Mi1C has quickly become the favorite everyday carry flashlight of GearVita users and for good reason. This exquisite flashlight is tiny, about two inches in length, perfect for putting in your pocket or keeping in a bag. But don't let its small size fool you, this little EDC light is durable, powerful, and everything you need in a pocket flashlight: https://gearvita.com/klarus-mi1c-mini-led-flashlight-600-lumens.html
Related products:
https://gearvita.com/fenix-ld15r-right-angle-flashlight-500-lumen.html
https://gearvita.com/olight-ion-rechargeable-led-flashlight-320-lumens.html
Main Parameters:
Beam Distance: 40m
Product Features:
Related products:
