HKJ
[size=+3]LG 20650 HG6 3000mAh (Blue)[/size]
Official specifications:
This is a high current cell with slightly larger diameter than 18650 cells.
The discharge curves tracks nicely, but I do not get rated capacity, it may be because I do not discharge to 2V or it might be because the batteries must be charger to 4.35V for full capacity.
[size=+3]Conclusion[/size]
This is the smallest of the newer larger cells and it do well for its side.
[size=+3]Notes and links[/size]
Vapcell told me that I was missing some cells in my comparator and they would be happy to supply them.
How is the test done and how to read the charts
How is a protected LiIon battery constructed
More about button top and flat top batteries
Compare to 18650 and other batteries
Compare to 26650 and other batteries
- Max. continuous discharge current: 30A
- Nominal capacity: 3000 mAh
- Nominal voltage: 3.6 V
- Discharge end voltage: 2.0 V
- Charging voltage: 4.20 +/- 0.05 V (Some say 4.35V)
- Standard charging current: 1500 mA
