Test/review of Liter INR20650 3400mAh (Blue)
HKJ
Copenhagen, Denmark
[size=+3]Liter INR20650 3400mAh (Blue)[/size]
Official specifications:
  • Model Number: NCR20650
  • Nominal Capacity: 3400mAh
  • Nominal Voltage: 3.7V
  • Charge Method: Constant Current Constant Voltage
  • Charge Voltage: 4.2V
  • Charge Current: 2065mA
  • Weight: 58g
  • Size:20x65mm
  • Made in: Korea
A 20650 battery with not that much capacity for the size, how much current can it deliver?
These discharge curves do not look very good, the batteries are a bit mismatched and they can barely deliver 7A.
At least they stay fairly cool.
[size=+3]Conclusion[/size]
When batteries get larger I generally expect more capacity or more current, or even both, but this battery has less of both. A good 18650 has the same capacity and can deliver more current
[size=+3]Notes and links[/size]
How is the test done and how to read the charts
How is a protected LiIon battery constructed
More about button top and flat top batteries
Compare to 18650 and other batteries
