Light with throwy flood
Phaetos
Woods back up to our house, maybe 20 yards to the first woodline with a field off to the left and the secondary woodline being about 200-300 ft away. We've sighted a coyote or two and a pack of dogs coming out there. We have our own pets and a motion floodlight on the back of the house, but it doesn't get out that far.
Im looking for a handheld light with a simple on/off clicky with on being full power all the time. Runtime is not an issue, it will be for spotting out the property at night before taking the pets out on leashes. LED, cool white, throwy with a good flood pattern. Budget around $80.
Any takers? I have an older Fenix something, but it doesn't quite get there on the distance.
archimedes
CONUS, top left
Save up for a Malkoff ?
M61 ~ 300' ~ $115
M61T ~ 450' ~ $140
M61HOT ~ 600' ~ $150
HD ~ 1000' ~ $190
SHD ~ 1500' ~ $270
I realize these are over budget, but it should be a "buy once" item ....
EDIT ... to add that the M61 and the HD, from the above list, will most closely match the beam shape you want ;)
Keitho
CO, USA
I've got two lights in my house that might meet those kinds of needs...one is more expensive and maybe more convenient, the other is a less expensive but very capable value.
The Acebeam L16 has a USB charger, decent throw/flood mix, and the UI is awesome. That is, the tailcap switch is turbo, no matter what, every time. The light is useful for around-the-house tasks at lower-than-turbo settings because it has a secondary side button: click it to turn on, hold down to cycle through brightness settings, click to turn off. Easy. But, it comes at a price--outside your budget by $20 including batteries.
Well under your budget, my other recommendation loses the USB charging (charge batteries in an external charger), and the UI is more traditional: double click always brings you to turbo, but a single click brings you back to whatever brightness you were using last time. Hold down the button to ramp up and down in brightness--very cool, but maybe not what you're looking for. If you always leave it on turbo, then that UI is just peachy. There are lots of lights in this category, but I think its one of the best cost-performance ratios in flashlights--the Emisar D1s. It is only $35 (without batteries), and might look a little large to you. So, maybe consider the Emisar D1, also $35, smaller size, less throw and a little more spill (but still pretty throwy).
That's just what I have in my collection. So, stay tuned for other good options--there are lots that others have in this category. Best of luck!
thermal guy
ny
I might get slack for this but I'm telling you the new crop of mag lights are awesome. The 3 D model will throw 300 plus yards and has a very good flood. Super bright as well.
Phaetos
M61 ~ 300' ~ $115
M61T ~ 450' ~ $140
HD ~ 1000' ~ $190
SHD ~ 1500' ~ $270
Malkoff seems to offering a new buyer discount, 20% off first purchase. Might sway me that way, but they seem to be rated at only 480 lumens.
Phaetos
I like The ui options on the acebeam light. Pretty simple, need it to be for the wife. If she has to click thru to get where she wants it, she won't use it. But it's pricey.
The emisars seem seem like a good option, but are out of stock. I need to make an order like yesterday.
ZMZ67
Colorado
The Malkoff Hound Dog is what came to my mind but as archimedes illustrated it is over your budget. You have the choice of the MD4 body or the 18650 (MD2) depending on your battery preferences. It might be worth your while in the long run to spend a the extra money and get the quality and reliability of a Malkoff.
EDIT to add:
The Hound Dog runs between 1000 - 1200 lumens. The M61s are a cheaper option than the Hound Dog but I don't think they will give you the throw your looking for.
Phaetos
What about the t16s from acebeam?
archimedes
CONUS, top left
Well, for me, 450 measured out-the-front real lumens is ... a lot :shrug:
How many lumens do you need, or want ?
Candlestick
I am eying a zebralight sc600w mk IV HI for the same purpose, a really bright light with a decent throw, hopefully without the tunnel vission effect of dedicated throw lights. I have to reccomend that you find a good High CRI light, it is much easier to spot wildlife and details!
Phaetos
Umm, sun bright? 😂 I don't just want the beam to "reach" the woodline by default due to light moving in a single direction, I want it to be BRIGHT where the light hits the woods.
Candlestick
^This, when you get a Chinese knockoff light, their posted 1000 lumens is theoretical, not accouning for losses through the reflector and window, and probably steps down to sub 300 lumens within 30 seconds. Plus quality over quantity plays a bigger role as you go brighter.
Phaetos
I've been looking at the fenix lights too. My old T1 still goes strong, but even with new batteries on high, it won't reach as far as I want it to. The newer lights at fenix are much improved and are still very reasonably priced. Are Fenix still gtg?
archimedes
CONUS, top left
LightObsession
The Coast Polysteel 650 might do the trick. 800' range.
Adjustable focus.
Always comes on in high.
Powered by 4 AA batteries of any chemistry.
Fresh Light
Stratford WI
I would very much recommend getting a Convoy L6 for 64.00 from a US seller like Mountain Electronics so you can have it in 3 days or so. I cant think of more light for the money. 4000+ actual lumens is pretty nice as well.
Also, If you are looking for considerably more throw and a bit smaller I'd get the Thrunite catapult v6.
archimedes
CONUS, top left
Yeh, that would be nice but that is getting waaayyy over what I can get away with spending.
Understood. Then, I would agree with @Keitho ...
.... Well under your budget, my other recommendation loses the USB charging (charge batteries in an external charger), and the UI is more traditional: double click always brings you to turbo, but a single click brings you back to whatever brightness you were using last time. Hold down the button to ramp up and down in brightness--very cool, but maybe not what you're looking for. If you always leave it on turbo, then that UI is just peachy. There are lots of lights in this category, but I think its one of the best cost-performance ratios in flashlights--the Emisar D1s. It is only $35 (without batteries), and might look a little large to you. So, maybe consider the Emisar D1, also $35, smaller size, less throw and a little more spill (but still pretty throwy)....
... but, if you are really set on single mode, you could try asking @vinhnguyen54 if he could do a custom D1vn with that UI for you.
If you don't mind the more complex standard UI, the base "vn" SST40 upgrade to the stock D1 kicks it up to 1900 lm / 470 m throw.
I do think that you would prefer the D1(vn) over the D1S(vn) , in terms of beam shape.
