Utorch SF01 - Delicated to Overcoming Difficulties in Your Adventure
gearvita
The Utorch SF01 is an extremely powerful and high performing handheld searchlight. It utilizes a Cree XR-ER2 LED with a maximum output of 350lm, offering 3 lighting modes and a strobe mode. Powered by a CR123, AA or AAA batteries, the upper switch offers one-handed operation and allows you to select from three gears for your options. The precision reflecting system ensures powerful lighting in illumination and distance, premium aluminum alloy body provides a long service life for you. It's small but bright, simple but functional, well-built and incredibly lite weight, perfect for your outdoor adventures, camping trips and anywhere else you need a sufficient amount of light.
Main Parameters:
Emitter: Cree XR-ER2 LED
Battery: CR123, AA or AAA
Lumen: 350lm
Shell Material: alumimum alloy
Working Voltage: 3V
Current: 1A
Working Time: 3h
Lighting Distance: 50m
Product Features:
● Cree XR-E R2 LED in use, emits 350lm cold white light, bright to reach 50m away.
● 3W low power consumption for reliable illumination.
● Powered by a CR123 non-rechargeable battery, is capable for 3 hours long.
● With robust aluminum alloy shell, SF01 is splashproof and unlikely to break.
● 3 lighting modes to cope with most circumstances easily.
● You will love the soft touch of the button, push it differently to change the lighting effect.
● As long as a cigarette, only takes up a little space.
● It has a clip for being attached firmly to belt, bracelet or pocket.
This is a quite cheap flashlight and can fulfill its purpose, you can buy it from GearVita at $8.99: https://gearvita.com/utorch-sf01-led-flashlight-350-lumens.html
Related products:
convoy s2+
wuben e502
