gearvita
- Joined
- May 17, 2018
- Messages
- 129
Lumintop ODF30C flashlight is an upgraded version of previous ODF30, compared to ODF30, it added a rechargeable ability through the new micro USB rechargeable port. ODF30C utilizes a high power XHP 70.2 LED, and runes on one high capacity 26650 Li-ion battery. It emits a max output up to 3500 lumens and a max burn time of 250 hours. By adopting an orange peel reflector and flood light design, it creates a wide and balance beam. Compact design, side switch simple UI well fits for one hand control. Three output levels plus three hidden modes allow it to meet for various applications. The compact design, side switch operation and the IP68 rated protection makes the ODF30C is a versatile companion and is essential for outdoor activities such as cave exploration, hiking, camping, and night walks etc.
Main Parameters:
LED: Cree XHP 70.2 LED
Light Color: Cool white
Power Source: 1 x 26650 Li-ion battery
Max Output: 3500 lumens
Peak Beam Distance: 280 meters
Peak Beam Intensity: 19,600cd
Waterproof: IP68, underwater 2m
Impact Resistance: 2m
Output and Runtime:
Low: 150 lumens ( 21hrs )
Med: 540 lumens (5hrs 45mins )
High: 1800 lumens ( 2hrs 15mins )
Turbo: 3500 lumens ( 3mins + 2hrs 5mins )
Eco: 8 lumens ( 250hrs )
Strobe/SOS/Beacon: 1800 lumens ( / )
Product Features:
● Utilizes Cree XHP 70.2 LED with a lifespan of 50,000 hours.
● Powered by one rechargeable 26650 Li-ion battery.
● 5 output levels plus Strobe, SOS and Beacon with a max 3500 lumens output.
● High efficiency circuit with a max runtime up to 250 hours.
● High-precision aluminum alloy orange peel reflector creates a wide and balance floody beam.
● Micro USB fast charging with 2A max charging current.
● Blue plating stainless steel bezel makes more attractive and reliable.
● Side switch controls all functions, fast and convenience.
● Toughened ultra-clear glass lens with anti-reflective coating.
● Electronic lock-out function prevents accidental activation.
● Enhance cooling fins ensure a comfortable holding.
● Low voltage indicator reminds to change or charge the battery in time.
● Intelligent temperature control system ensures a safety use.
● Flat tail cap with tail standing ability to serve as a candle.
● Made of aerospace-grade aluminum alloy, premium Type III hard-anodized anti-abrasive finish on the surface.
● IP68 rated dust and waterproof classification, impact resistance to 1.5 meters.
Looking for a powerful, yet affordable torchlight? Come to GearVita, the ODF30C may gives you some surprise and fit your list: https://gearvita.com/lumintop-odf30c-led-flashlight-3500-lumens.html
Related products:
lumintop gt mini
lumintop odl20c
Main Parameters:
Output and Runtime:
Product Features:
Related products:
lumintop gt mini
lumintop odl20c
