So I lent my coworker my Streamlight Protac and he proceeded to drop it in the sewer so needless to say I am in the market for a new EDC. I was perusing around and came across this gem of a website...I had no idea a family of flashlight fanatics like this existed so I am pretty excited to give this a shot. I work in underground utilities so am exposed to zero light environments in pretty large spaces but also want to carry the same light for everyday personal use. I probably checked more than I should but I am pretty flexible, just looking for something with at least 2 variable outputs. And money is not an issue so looking to see your guys opinions on the best EDC money can buy MW
____I would like to purchase the light in person from a brick and mortar store. I am located in ______________.
__X__This will be mail-order or Online (location doesn't matter).
2) Budget: An easy question, but you may change your mind after answering the rest!
____I don't know yet
____Up to $25.
____Up to $50.
____Up to $100.
____Up to $200.
____Up to $300.
__X__Essentially unlimited.
3) Format:
____I am not sure, please help me decide.
__X__I want a flashlight (hand held/self contained).
____I want a self-contained headlamp.
____I want a headlamp with an external pack/power source.
____I want a mounted light (typically for a bicycle or vehicle)
____I want a lantern/area light.
____I want a portable spotlight (it may have an external power source).
____Other ____________________________________________
4) Size:
____MICRO - Keychain size.
____TINY - Every day carry (2-4 inches).
__X__SMALL - Every day carry (4-7 inches).
____MEDIUM - Holster/belt ring carry. (>7 inches)
____LARGE - Big enough to need its own travel case.
____I don't know/I don't care.
5) Emitter/Light source:
____LED (known for efficiency, longevity, and compactness)
__X__I don't know.
6) Manufacturer:
__X__I want to buy a light from a large/traditional manufacturer that is ready to go out of the box.
__X__I would like a light from a specialty manufacturer (Possibly limited run/Custom).
____I am interested in assembling my own components. (for example a "host" or flashlight body from one manufacturer, and a "drop-in" emitter from another source).
____I intend to use "Primary"/Disposable Alkaline
____Any size switch will do.
____I need a BIG switch (I'll be using gloves or have very large hands or coordination issues).
____I want a forward clicky (Helpful for momentary activation and signaling).
____I want a momentary switch (Predominantly for use with signaling and short bursts of momentary light only).
____I want a body mounted switch (near the head, like on a Maglite).
____I want a tail mounted switch (found on the majority of today's high end lights).
____I want a remote switch (usually found on high-end bicycle headlights)
__X__I don't care.
____I don't know.
13) User Interface (UI) and mode selection.
____Anodized Aluminum – either type II or III (Hard Anodized) (Aluminum, specifically HA, is the most common material/finish for today's higher end flashlights).
____Stainless steel (durable, but much heavier than aluminum)
____Titanium (durable and nearly as lightweight as aluminum, but can be moderately to significantly more expensive).
____I don't care.
__X__I don't know.
15) Water resistance
____Up to $25.
____Up to $50.
____Up to $100.
____Up to $200.
____Up to $300.
__X__I don't know.
batteries based on the usual AAA/AA/C/D sized cells common to most stores.
Lithium____I intend to use "Primary"/Disposable
batteries based on the usual AAA/AA/C/D and CR123 sized cells common to most stores (often a cold weather or long storage choice).
__X__I intend to use
Rechargeable cells__X__I intend to use
(NiMH or NiCD) based on the usual AAA/AA/C/D sized cells common to most stores.
based on less common formats (18500 or 18650 Li-Ion, RCR123, et-al).
__X__I want a light with an integrated rechargeable battery pack.
____I don't know/I need more information on power sources.
7a) If you have selected a rechargeable option__X__I want a light with an integrated rechargeable battery pack.
____I want a light that plugs directly into the wall (literally with prongs built into the light)
____I want a light that has a recharging adapter (your typical "wall wart")
____I want a light that snaps into a cradle (usually mounted on a wall)
____I want a separate/stand-alone charger (this involves removing the batteries to charge)
__X__I don't care
8) How much genuine out the front (OTF) light do you want/need? ____I want a light that has a recharging adapter (your typical "wall wart")
__X__I don't care
Sometimes you can have too much light (trying to read up close up with a 100 lumen light is not a happy experience).
____I want to navigate a dark room or read a map (1-10 lumens).
__X__I want an indoor "blackout" light (15-50 lumens)
____I want to confidently walk around an unlit/unpaved rural area (60-150 lumens).
__X__I want to illuminate my entire backyard or a campsite (150-300 lumens).
____I want to illuminate an entire field, the neighbor's front yard several houses down, impress my friends and neighbors, etc. (300-700 lumens).
__X__I want search and rescue type illumination (800+ lumens).
__Maybe__
SPECIAL NOTE: Burst/Turbo mode Category____I want to navigate a dark room or read a map (1-10 lumens).
__Maybe__
- There are several lights that will run at a super bright maximum for a very limited period (usually 5-10 minutes) and then will "step-down" to a lower level for thermal control. Check here if this is acceptable.
9)
Flood vs Throw:9)
Flood covers an area, Throw reaches out to a distance.
____All Flood: I am doing "arms length" tasks like reading and campsite cooking.
__X__Wide Flood: I want a defined flood area for semi-close tasks like after-dark campsite tasks or working on a car.
____Narrow Flood: I want a sharply defined flood area that will project some distance for tasks like trail walking.
__X__Wide Throw: I want a beam with a noticeable hot-center for distance throw and a significant amount of "side-spill". Good for rough trail hiking, search and rescue, and general distance work.
____Narrow Throw: I want a beam with a very tight "hot center" and minimal "side-spill". Good for distance viewing, fog, and looking through dense undergrowth.
____Turbohead: I want a far-distance projector with a sharply focused spot of light and minimal or zero side-spill. Good for extreme distance and impressing your friends.
9a) Distance: How far away will you typically need to see with this light____All Flood: I am doing "arms length" tasks like reading and campsite cooking.
(check all that apply)
____Less than 1 yard/meter (reading, other close work)
__X__Less than 5 yards/meters (looking for something inside a dark shed/garage/basement)
__X__5-20 yards/meters (check out a noise in the backyard)
__X__150+ yards (I am searching from a helicopter)
10) Runtime:____Less than 1 yard/meter (reading, other close work)
Not over-inflated manufacturer runtime claims, but usable brightness measured from first activation to 50% with new batteries (Measured on maximum continuous output).
__X__Up to 30 minutes (I want the brightest [and potentially smallest] light for brief periods)
____30-60 minutes (I have plenty of batteries just ready to be changed)
__X__90-120 minutes (Runtime is moderately important, but still not critical)
____3 hours + (I critically need this light to run on max for extended periods in between battery changes/charges).
11) Durability/Usage:__X__Up to 30 minutes (I want the brightest [and potentially smallest] light for brief periods)
Generally the old phrase "you get what you pay for" is very accurate for flashlights.
____Not Important (A "night-stand" light).
__X__Critical (Police, Fire, Search & Rescue, Caving, Survival).
____I don't know.
12) Switch Size, Type, and location (choose all that apply):____Not Important (A "night-stand" light).
____I don't know.
__X__I don't care.
____I don't know.
Select all that apply.
____A simple on-off with only one output level is fine for me.
__X__I want 2 light levels. (Brighter/short runtime and Dimmer/long runtime.)
__X__I want multiple light levels. (Some lights have 5-16 light levels.)
____I want a selector ring.
____I want a strobe mode. (Oscillating pattern to confuse/blind aka "Police Mode")
____I want SOS mode. (blinks in ...---... emergency pattern)
____I want a beacon mode. (Regular flashes at full power to show location.)
____I don't care.
____I don't know.
14)Material/Finish/Coating____A simple on-off with only one output level is fine for me.
____I don't care.
____I don't know.
____I don't care.
__X__I don't know.
____None needed
____IPX4 (Splash resistant)
__X__IPX7 (Waterproof to 1 meter/30min)
____IPX8 (Submersible to greater than 1 meter for 4 hours)
16) Storage conditions____IPX4 (Splash resistant)
____In house (temperature/climate controlled environment)
____Emergency kit (long standby periods)
____Automobile glove-box (wide temperature swings, long standby periods, critical reliability)
__X__Other_______All Weather Outdoor Use - I live in the northeast so a wide swing in temperature____
17) Special Needs/extras:____Emergency kit (long standby periods)
Is there anything else you want or need that hasn't been mentioned? Select any/all below.
____"Hybrid" light (bright incandescent combined with long running LEDs)
__X__Pocket/belt clip
____Holster
____Wrist/Neck Lanyard
____Crenulated bezel
____Non-sparking, Intrinsically Safe (IS) for use in explosive environments
____Holster
