eyesonfire
- Joined
- Jun 23, 2012
- Messages
- 121
Does the Maxa Beam run off of 12 V?
If so will it work plugged into a CLA?
Thanks.
Thanks.
Cigarette Lighter Adapter sounds more logical in his post. If that's the case then assuming a latching-High Gen3 light with 85 Watts at the lamp plus a guessed 25% overhead load would total about 106 Watts divided by an even 12 Volts would equal about a 9 Amp load. Starting Amps will be higher. If CLS's are fused at 10 Amps, I would guess that a Gen3 MB would not be a good candidate for CLA use. Even a Gen2 at 75 Watts would draw close to 8 Amps plus additional starting load.
..... So if not powered from the lighter, it can be hard wired to a sufficiently fused 12V system?
Thanks.
