Nitecore TM06S - Successor of TM06, Lighter, Longer Throwing, Brighter Lumens
gearvita
The Nitecore TM06S is a longer throwing, brighter lumened, more lightweight upgrade to its TM06 predecessor. The light boasts 365 yards, 27 more than the original, and a blinding 4000 lumens, 200 more than the original. Even with these impressive improvements, the TM06S is still able to weigh even less than its predecessor at a compact 9.38 ounces. Five brightness levels are ready to be called upon for whatever scenario you find yourself in. A convenient side switch easily toggles through brightness levels or special modes of strobe, SOS, or beacon. The side switch will also blink to indicate remaining battery voltage so you won't be caught without power.
Main Parameters:
LED: Cree XM-L2 U3
Max output: 4000 lumens
Beam Distance: 359 meters
Beam Intensity: 32300cd
Max Runtime: 560h
Battery: 4 × 18650
Waterproof: IPX-8 (2 meters submersible)
Impact Resistant: 1.5 meters
Output and Runtime:
Turbo: 4000 lumens ( 1h )
High: 1500 lumens ( 5h )
Mid: 480 lumens ( 11h 15min )
Low: 160 lumens ( 32h )
Lower: 3 lumens ( 560h )
Strobe: 4000 lumens ( / )
SOS: 4000 lumens ( / )
Beacon: 4000 lumens ( / )
Product Features:
● Utilizes four L2 U3 LEDs.
● Uses four 18650 batteries for maximum runtime up to 560 hours.
● Features advanced temperature regulation (ATR) technology.
● Innovative two-stage side switch accesses various modes and functions.
● Integrated power indicator in side switch indicates remaining battery power.
● Power indicator displays battery voltage accurate to 0.1V.
● Intelligent memory function for brightness levels.
● Direct access to ultralow and turbo outputs.
● Toughened ultra-clear mineral glass with anti-reflective coating.
● Integrated "Precision Digital Optics Technology" provides extreme.
● Stainless steel bezel ring protects core components from damage.
● Constructed from aerospace grade aluminum alloy.
● HAIII military grade hard-anodized.
● Waterproof in accordance with IPX-8 (submersible to 2 meters).
● Tail stand capability.
This compact light truly is a tiny monster, get it from GearVita, it can be taken anywhere in your backpack or pocket. It is perfect for law enforcement, military, searching, camping, hiking, exploring, security, or anything else that requires extreme luminosity and beam throw: https://gearvita.com/nitecore-tm06s-led-flashlight-4000-lumens.html
Hot sale products:
xiaomi 70 minutes smart wifi car dvr
oneplus 6T 4g smartphone 256gb
