Candidates for White1 & White2 (W1 &W2)
Skylumen
6500K tint only
White1 = W1 = OSRAM KW CSLNM1.TG – 1mm2 = 960L @ 5A/3.4Vf
White2 = W2 = OSRAM KW CSLPM1.TG – 2mm2 = 1550L @ 8.5A/3.3Vf
This suggest W1 has more throw as it has about 25% more surface brightness
  1. P60vn Smooth Reflector W2 900L, 60Kcd, 490m Throw, LG 3500mAh + FS54 + Solarforce host
  2. D4Svn W1 3000L, 126Kcd, 707m (Turn On)
  3. D4Svn W2 4800L, 110Kcd, 663m (Turn On)
  4. D4vn W1 2500L, 54Kcd, 465m (Turn On), 10A Cells Max
  5. HPLvn W1 400L, 180Kcd, 848m Compared to XPL HI 880L, 116Kcd, 680m
  6. HPLvn W2 475L, 132Kcd, 726m
  7. EC65vn W1 2100L, 46Kcd, 429m
  8. EC65vn W2 2500, 33Kcd, 363m
  9. ​PD35vn V2 W1 600L, 43Kcd, 415m
  10. ​HC33vn W2 1000L, 28Kcd, 335m
  11. SDminiVN W1 700L, 62Kcd, 498m
  12. E07vn W1, 4700L, 70Kcd, 529m (Turn On)
  13. E07vn1 W2, 5850L, 58Kcd, 482m (Turn On)
  14. D25Cvn W1 675L, 37Kcd
  15. D25Cvn W2 900L, 32Kcd
Skylumen
Re: Candidates for Oslon White
Look at how tight the hot spot is!!! Beam looks almost like a reflector beam.
aginthelaw
NJ, USA
Now I'll have to send you one of my m43's. I don't think I can part with another vn light. I have a stock s41 that I might have to send
twistedraven
Took the MT18 off the list huh. :p Centering that LED 18 times for the optics would be a difficult task.
Agpp
I wonder what would it do in Led Lenser P3 AFS....the low Vf is great for use with small cells. :)
Skylumen
I think it makes more sense to say that Black is for Single LED applications while White is for multi LED applications. Not reflector VS optics.
id30209
Croatia, EU
As a P60 persona, that D4 beamshot says all. This one is made for multiple emitter choice where i'm thinking of P60 quad. This would be the first quad thrower ever. Any plans for building some? [emoji3]
Skylumen
My goal is to put this LED in everything in post 1 ;-)
I think Triples will throw even more than Quads but of course Quads has a bit more lumen.
